726
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Jamze
    Ice Cream Sandwich Jan 17, 2020
    Jamze , Jan 17, 2020 :
    Amusing. Lando is an F1 driver though, he can use what he wants. Guess OnePlus PR are happy to turn a blind eye as those two have 2.4 million followers.
    Caomhin likes this.
  2. F_Avramis_Phylactou_SjCd
    Cupcake Jan 17, 2020
    Q1533309568683, Caomhin and drl431 like this.
  3. Caomhin
    KitKat Jan 17, 2020
    ironass likes this.
  4. JAGADISH BHATTA
    Jelly Bean Jan 17, 2020
    JAGADISH BHATTA , Jan 17, 2020 :
    That must be fixed by wynk music developers my guess wynk music is not yet ready for android 10.
    DarKrypton and Caomhin like this.
  5. JAGADISH BHATTA
    Henkan and Caomhin like this.
  6. JAGADISH BHATTA
    Slow motion video needs to be shot in daylight for self update your launcher from playstore
    Caomhin likes this.
  7. Sajan_Shrestha1125
    Caomhin likes this.
  8. Caomhin
    KitKat Jan 17, 2020
    Caomhin , via OnePlus 6T , Jan 17, 2020 :
    If its for the game lagging you mentioned try one or all of the following.
    1. Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    How to calibrate your Battery
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    2. Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of 10.3.0. So you will need to backup your phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button,
    3. Please submit your issues directly to OnePlus use the following links to do so.
    Report a Bug
    Feedback tool
    https://forums.oneplus.com/threads/feedback-tool-lets-improve-oxygenos-together.1021893/
    Contact OnePlus support directly. Scroll down the page for contact details.
  9. NeV3rKilL
    NeV3rKilL , Jan 17, 2020 :
    Is it a known bug that after you paying with NFC you are not getting any feedback apart from a simple vibration?
    With OxygenOS 9 when I paid, I saw a fullscreen notification with the amount paid and the information. Now, with OxygenOS 10 I'm getting only a buzz.
  10. ravikantlinge
    ravikantlinge , Jan 17, 2020 :
    On upgrading after a month I'm getting internet slow speed issue on both the sims and even after interchanging sims in the slots still the speed is not getting increased...can any one have solution on this?
  11. Caomhin
    KitKat Jan 17, 2020
    You can try resetting the Mobile Network to see if this resolves the issue.
    Settings, System, Reset Options, Reset Mobile Network, this option resets all radios including WiFi and Bluetooth as well.
    ravikantlinge likes this.
  12. Caomhin
    KitKat Jan 17, 2020
    Try clearing the App info app cache within the Pay app you are using. Failing that, clear app info Storage cache as well and re set up your cards.
  13. Jamze
    Also, check the notification hasn't been turned off in settings.
    To turn purchase notifications off:
    1. On your mobile device, open the Google Pay app [​IMG].
    2. Tap Menu [​IMG] [​IMG] Settings [​IMG] Notifications.
    3. Switch Purchases off.
    Caomhin likes this.
  14. ravikantlinge
    can you tell me what are the steps?
    Caomhin likes this.
  15. Caomhin
    KitKat Jan 17, 2020
    ravikantlinge
    can you tell me what are the steps?​
    Try @Jamze suggestion above first.
    TO clear caches.
    Long press your Pay app icon, in the menu that appear click on App info, you will see the Storage & Cache option, in here choose Clear cache 1st, if that doesn't work, then clear storage. Clearing storage, resets everything in the app, so you will have to set up your cards again.
  16. ravikantlinge
    Thank you [e]1f60a[/e]
    Caomhin likes this.
  17. akku_boy18
  18. Caomhin
    KitKat Jan 17, 2020
    Check post #13631 about 10 posts up, suggestions given for similar issue.
