732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Kaysar01
    Cupcake Jan 18, 2020
    Kaysar01 , Jan 18, 2020 :
    where are they? kindly send me the link.
  2. Jamze
    Ice Cream Sandwich Jan 18, 2020
    Jamze , Jan 18, 2020 :
    If you use Internet forums to investigate an issue you have, use search first. Look at post 13632.
    S1553152189842 and Caoimhín like this.
  3. G1573549795380
  4. Jamze
  5. udaykumarc
  6. Caomhin
    OnePlus 9 Series Expert Community Expert Jan 18, 2020
    ironass likes this.
  7. Caomhin
  8. Caomhin
    Caomhin , via OnePlus 6T , Jan 18, 2020 :
    There are a number of things to try. See below.
    1. Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    How to calibrate your Battery
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    2. Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of 10.3.0. So you will need to backup your phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button,
  9. Mohammad Ashar
  10. Caomhin
    Try the steps in the post above yours, see if they resolve your issue.
  11. Tacco_
    Donut Jan 18, 2020
  12. Caomhin
    Literally suggestions given in a readable post, just a couple of posts up from yours. 🙄🙄
    Artemus likes this.
  13. Tacco_
    Donut Jan 18, 2020
    Tacco_ , Jan 18, 2020 :
    tried calibrating my battery not much of an improvement 🙁
  14. yogesh5727
    Gingerbread Jan 18, 2020
  15. Pdthepunisher
    Eclair Jan 18, 2020
  16. chetanved
  17. Caomhin
  18. JAGADISH BHATTA
    Jelly Bean Jan 18, 2020
    JAGADISH BHATTA , Jan 18, 2020 :
    Try uninstalling google app updates. For some unknown reason it is draining the battery
    Caoimhín likes this.
  19. belc
    Donut Jan 18, 2020
    belc , via OnePlus 6T , Jan 18, 2020 :
    No such issues, update is great. Your device must be faulty.
    danycmoi likes this.
  20. Pdthepunisher
    Eclair Jan 18, 2020
