728
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. yogesh5727
    Gingerbread Jan 18, 2020
  2. S1553152189842
    Cupcake Jan 18, 2020
  3. chetanved
  4. Caomhin
    KitKat Jan 18, 2020
  5. JAGADISH BHATTA
    Jelly Bean Jan 18, 2020
    JAGADISH BHATTA , Jan 18, 2020 :
    Try uninstalling google app updates. For some unknown reason it is draining the battery
    Caomhin likes this.
  6. belc
    Donut Jan 18, 2020
    belc , via OnePlus 6T , Jan 18, 2020 :
    No such issues, update is great. Your device must be faulty.
    danycmoi likes this.
  7. S1553152189842
  8. M1577219700899
    M1577219700899 , Jan 18, 2020 :
    hello,
    there are many bugs After update to android 10:
    1) there's a extra space below the keyboard, not very comfortable
    2) the system has lag, the frame rate going down to very low Fps, it's very frequently this situacion.
    3) the First Page of launcher with the widget, sometimes have a block and it'impossible ti scrolling down, only solution Is reboot system.
    i'm thinking to return to android 9... Better than this.
    ttamvo and S1553152189842 like this.
  9. Pinttas
    Honeycomb Jan 18, 2020
    Pinttas , Jan 18, 2020 :
    Almost a month with the 10.3.0 update.
    Zero problems 😉
    Thanks oneplus 👍
    tomol, Naveen_006 and Caomhin like this.
  10. Caomhin
    KitKat Jan 18, 2020
    Caomhin , via OnePlus 6T , Jan 18, 2020 :
    You can try the following to see if they can rectify your issues.
    1. Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    How to calibrate your Battery
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
    2. Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of 10.3.0. So you will need to backup your phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button,
  11. S1553152189842
    S1553152189842 , via OnePlus 6T , Jan 18, 2020 :
    u got it Right. one plus executive said u can degrad to 9.0.
    we have to degrade n waiting for next update
    M1577219700899 likes this.
  12. S1553152189842
    u cando it. i dnt hv tym for tht.
  13. P1577214451135
    Donut Jan 18, 2020
    P1577214451135 , Jan 18, 2020 :
    can somebody how to switch off completely vibration? [e]1f64f[/e][e]1f64f[/e][e]1f64f[/e]
    somehow I switched it off in second user space but cant do that in main space:(
  14. Caomhin
    KitKat Jan 18, 2020
    Well if you don't want to fix your issue, fine. Suffer on. I already reset mine, phone is top notch, working great. Absolutely no issues. If you don't want to be proactive, then there no point in moaning. Getting great battery life too. 🙄[e]1f44d[/e]
    Naveen_006, drl431 and Jamze like this.
  15. ttamvo
    ttamvo , Jan 18, 2020 :
    Updated to Android 10.3.0 and since than the system lags on my phone. Scrolling is slow and often applications get stuck.
    Same point 2 mentioned by you.
    _______________
  16. N1573283503560
    N1573283503560 , Jan 18, 2020 :
    Hi one plus after oxygen os 10.3 update my WhatsApp file sharing feature has been affected kindly fix this issue ... I need to restart my phone every time when the issue appears
  17. Jamze
    Ice Cream Sandwich Jan 18, 2020
    Jamze , Jan 18, 2020 :
    Takes about the same effort to go back to Pie. I've not needed to do the battery calibrate.
    JAGADISH BHATTA, ironass and Caomhin like this.
  18. papadis
    papadis , via OnePlus 6 , Jan 18, 2020 :
    After update to Android 10 in all versions I can't make a call using sip account with default phone app. I made a clear installation with reset before and after update. Is there possible to fix this bug on latest versions?
  19. N1547916502710
    N1547916502710 , Jan 18, 2020 :
    since updated, camera, finger print touch and approximity sensor Is not working...any One else having the same issue?
  20. Caomhin
    KitKat Jan 18, 2020
    Update your launcher app and camera app and see if they improve the experience
    Launcher, released a couple of days ago
    https://play.google.com/store/apps/details?id=net.oneplus.launcher
    Camera app released yesterday.
    https://www.apkmirror.com/apk/onepl...e/oneplus-camera-3-8-96-android-apk-download/
    ironass likes this.
