728
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Caomhin
    KitKat Jan 24, 2020
    Caomhin , via OnePlus 6T , Jan 24, 2020 :
    Install latest OOS 10.3.1 incremental update just released for 6T, 6 should be showing soon, it is a Staged Rollout, so if you don't see it via OTA, you may need to do it via 3rd party app Oxygen Updater from the Playstore, see if it fixes any issues you may have.
    In Oxygen Updater settings, set the update method to incremental.
  2. Kytharsis
    Marshmallow Jan 24, 2020
    Kytharsis , Jan 24, 2020 :
    T-Mobile is still doing its carrier updates (it's gonna be awhile before they support 10 on its "legacy devices") so this forum won't be any use to you.
    Caomhin likes this.
  3. Skoreykom
    Cupcake Jan 25, 2020
    Skoreykom , Jan 25, 2020 :
    Only been about 3 hours since i updated to A10 but it's been great so far. Haven't encountered any bugs. Wish i didn't hold off so long on doing the update.
  4. amitkr1282
  5. G1542828796976
    Gingerbread Jan 25, 2020
  6. Nvizer
  7. Caomhin
    KitKat Jan 25, 2020
  8. Caomhin
    KitKat Jan 25, 2020
    Caomhin , via OnePlus 6T , Jan 25, 2020 :
    This will not work for TMobile phones. International Global only.
    Install latest OOS 10.3.1 incremental & now full update released for 6T, 6 should be showing soon, it is a Staged Rollout, so if you don't see it via OTA, you may need to do it via 3rd party app Oxygen Updater from the Playstore, see if it fixes any issues you may have.
    In Oxygen Updater settings, you can set the update method to incremental if you are already on 10.3.0, if you are on any earlier version to this, set update method to full update.
    Then do the following.
    Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of 10.3.1. So you will need to backup your phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button,
    Kytharsis likes this.
  9. Kytharsis
    Marshmallow Jan 25, 2020
    Kytharsis , Jan 25, 2020 :
    First time I've seen a hotfix needing a full reset.
  10. Caomhin
    KitKat Jan 25, 2020
    The poster asked to update to 10.3.1 and then wipe the phone and start fresh.
  11. Kytharsis
    Ahhh. Gotcha.
  12. PimpaSzeged
    PimpaSzeged , Jan 25, 2020 :
    The Viber shut down regulary since i updated. I have been unable to attach a picture since i updated it regularly and the camera freezes many times since then. will there be an update? or how to downgrade to the previous OS because it was perfect.
    thx
  13. Kytharsis
  14. docMboot
    Cupcake Jan 26, 2020
    docMboot , Jan 26, 2020 :
    Me too. No update of any sort for months now: still on Android 9. That's starting to make me nervous. Security updates?. I'm starting to consider giving up on Oneplus.
    Jim Chinis likes this.
  15. Kytharsis
    Marshmallow Jan 26, 2020
    Kytharsis , Jan 26, 2020 :
    What update are you waiting on? And what device are you on?
    Caomhin likes this.
  16. Jim Chinis
    Eclair Jan 26, 2020
    Jim Chinis , via OnePlus 6 , Jan 26, 2020 :
    Hello, I'm on OS 9.0.9 (OnePlus 6) , I haven't updated to 10.3.0 yet because of all the bugs that I read about. Will I be able to get any future updates , or I need to proceed to the latest update first?
  17. Kytharsis
    You will get future updates but you have to be on 10 to get 10 updates, obviously.
    Caomhin likes this.
  18. Jim Chinis
    Eclair Jan 26, 2020
  19. Kytharsis
    Once it becomes available, then you'll have your answer. Are you sticking to 9 till the foreseeable future?
    Caomhin and Jim Chinis like this.
  20. Jim Chinis
    Eclair Jan 26, 2020
    Yes , I'm waiting on 9.0.9 , I would only update for the security patch, other than that I am scared that I will ruin my device .
