730
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. F1579606598396
    Cupcake Apr 29, 2020
  2. Artemus.
    Nougat Apr 29, 2020
    Artemus. , Apr 29, 2020 :
    That's... normal.
    Caomhin likes this.
  3. F1579606598396
  4. Artemus.
    Nougat Apr 29, 2020
    Uh... no? Since it's highly subjective and based on your usage.
    Caomhin likes this.
  5. Atul Darne
    Cupcake Apr 30, 2020
  6. F1579606598396
  7. Caomhin
    Lollipop Apr 30, 2020
    Caomhin , via OnePlus 6T , Apr 30, 2020 :
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
  8. J1577271112158
  9. H1572669940024
    Cupcake May 1, 2020
    H1572669940024 , May 1, 2020 :
    please provide me an update
  10. Artemus.
    Nougat May 1, 2020
    Artemus. , May 1, 2020 :
    You do realize you're both posting in the 10.3.0 thread when 10.3.0 exists?
    Caomhin likes this.
  11. F1579606598396
    Cupcake May 2, 2020
  12. Caomhin
    Lollipop May 2, 2020
    Caomhin , via OnePlus 6T , May 2, 2020 :
    ROLL-BACK FROM CURRENT ANDROID 10 Beta or Stable TO EARLIER STOCK ANDROID 9 OR 10
    Thanks to @ironass for putting this together.
    This Link will guide you through the Downgrade process.
    https://forums.oneplus.com/threads/roll-back-to-stock-android-9-or-10.1215079/
    All Downgrades to earlier builds involve wiping the phone.
    So you will need to backup your phone data.
    If you can, you could try a Full Factory Reset to fix the issue. Steps below to Factory Reset the phone.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    Your phone will now restart and go through the Full reset cycle.
    And its always good practice to backup phone data before upgrading.
    Artemus. likes this.
  13. F1579606598396
    Cupcake May 2, 2020
  14. F1579606598396
    Cupcake May 2, 2020
  15. F1579606598396
    Cupcake May 7, 2020
  16. Artemus.
    Nougat May 7, 2020
    Artemus. , May 7, 2020 :
    Why ask in this thread?
    Caomhin likes this.
  17. F1579606598396
    Cupcake May 7, 2020
  18. F1579606598396
    Cupcake May 9, 2020
    F1579606598396 , May 9, 2020 :
    my phone is being lag nowadays ...in messenger when i share screen i see very much lag ni my phone...how many of you see too...??
  19. Artemus.
    Nougat May 9, 2020
    Artemus. , May 9, 2020 :
    Why do you keep posting in this thread rather than the proper update thread?
    Caomhin likes this.
  20. CS1o
    Cupcake May 19, 2020
    CS1o , May 19, 2020 :
    Hey guys the new Update for the 6T just broke the Clock on Mainscreen again like the first android 10 version. Hope they fix it again...
