731
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. ItsRavi25
    Ice Cream Sandwich Aug 19, 2020
  2. JoshuaJordison
    Donut Aug 21, 2020
    JoshuaJordison , Aug 21, 2020 :
    Guys anybody else facing battery drain issues after the recent update of 10.3.5 ??? If so any remedy please ?
    mik29194, Balaji6t and Caomhin like this.
  3. Caomhin
    Marshmallow Aug 21, 2020
    Caomhin , via OnePlus 6T , Aug 21, 2020 :
    Have you checked your Battery Stats to see what app or apps are using so much battery?
  4. JoshuaJordison
    Donut Aug 21, 2020
    oh yes I don't see any of the apps consuming battery more than Avg of 3.5%, also I have resticted the background running of apps like Outlook, Teams & WebEx which I use day in and out for my work related stuff
    Caomhin and ItsRavi25 like this.
  5. Caomhin
    There are a couple of links at the bottom of this suggestion to check as well, because battery drain could be for a variety of reasons.
    Try to Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Guide to lower Batter Drain.
    JoshuaJordison and ItsRavi25 like this.
  6. JoshuaJordison
    Donut Aug 21, 2020
    I really appreciate for your time and help ! Thanks much and Cheers !!
    Caomhin likes this.
  7. Caomhin
    You're welcome 😎[e]1f44d[/e]
  8. E1575876447240
    Cupcake Aug 21, 2020
    OnePlus.rksharma likes this.
  9. Caomhin
    [e]2b06[/e]️[e]2b06[/e]️ Suggestions given for battery drain 3 posts up [e]2b06[/e]️[e]2b06[/e]️
    ASMITSHARMA2003 and Hemangb2 like this.
  10. OnePlusSQRT36
    Gingerbread Aug 21, 2020
  11. Creaco
    Gingerbread Aug 25, 2020
    Creaco , via OnePlus 6T , Aug 25, 2020 :
    Post on the right thread!!!!!
    Atharv_des, Caomhin and OnePlusSQRT36 like this.
  12. AlexanderDG83
    Eclair Aug 25, 2020
    AlexanderDG83 , via OnePlus 6 , Aug 25, 2020 :
    Extra 1.5 hour is impressive! [e]1f609[/e]
    Hemangb2 likes this.
  13. N1518121409396
    Donut Sep 6, 2020
    N1518121409396 , via OnePlus 6T , Sep 6, 2020 :
    After last update cannot get properly Wi-Fi connection
    OxygenOS 10.3.5 OnePlus 6T,😟 oops anyone have this problem this is my after last update I cannot get proper leave Wi-Fi but data its ok
  14. Caomhin
    Marshmallow Sep 6, 2020
    Caomhin , via OnePlus 6T , Sep 6, 2020 :
    Reset your WiFi adapter, see if that helps.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    How To Fix Common Wi-Fi Problems In Android
    https://www.techjunkie.com/fix-wi-fi-problem-android/
    Also a suggestion here for 8 Series but some of the suggestions may crossover to other OnePlus series phones.
    https://forums.oneplus.com/threads/my-findings-of-the-5-ghz-wifi-connection-issue.1221263/
    ItsRavi25 likes this.
  15. E1535482230150
    Donut Sep 6, 2020
    E1535482230150 , via OnePlus 6T , Sep 6, 2020 :
    Dear friends,
    Im facing update issue for Google its been one mnth so far and while clicking on update the chrome is not gettung updated olz help me out of this.....!!
    H1557058226130 likes this.
  16. Caomhin
    Clear the Playstore App info Cache and App info Storage.
    Also clear the Google Play Services App info Cache and App info Storage as well.
    See if that helps
  17. E1535482230150
    Donut Sep 7, 2020
    E1535482230150 , via OnePlus 6T , Sep 7, 2020 :
    I tried but nothing has changed.....
  18. Caomhin
    Marshmallow Sep 7, 2020
    Caomhin , via OnePlus 6T , Sep 7, 2020 :
    Do a Full Factory Reset
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    [e]26a0[/e]️Enable Erase Internal Storage[e]26a0[/e]️
    https://www.androidpolice.com/2020/07/18/how-to-back-up-your-android-phone-before-a-factory-reset/
    And here
  19. Jain Rakshit
    Donut Sep 8, 2020
    Jain Rakshit , via OnePlus 6T , Sep 8, 2020 :
    After 10.3.5 update..., My device comprises with the camera quality... If I rate it, then I would give 7 out of 10 as compared to earlier. For reference, I attached two pictures with the comment...
  20. OnePlusSQRT36
    Gingerbread Sep 9, 2020
    OnePlusSQRT36 , via OnePlus 6 , Sep 9, 2020 :
    I am seeing the opposite. On average about the same if not approx an hour more... This release to my surprise has been amongst the best for me after 10.3.2
    Caomhin likes this.
