732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. patanjali kumar
    Cupcake Sep 11, 2020
    Atharv_des likes this.
  2. N1518121409396
    Eclair Sep 13, 2020
  3. N1518121409396
    Eclair Sep 13, 2020
  4. ItsRavi25
    Jelly Bean Sep 13, 2020
    ItsRavi25 , via OnePlus 6T , Sep 13, 2020 :
    Goto settings> System > Reset options > Reset wifi, mobile network etc...
    Caoimhín likes this.
  5. Caoimhín
    OnePlus 9 Series Expert Community Expert Sep 13, 2020
    Caoimhín , via OnePlus 6T , Sep 13, 2020 :
    Reset your WiFi adapter, see if that helps.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Also Go to Settings->Battery->Battery Optimization->Search com.oneplus.wifiapsettings -> Change this to "Don't optimize"
    How To Fix Common Wi-Fi Problems In Android
    https://www.techjunkie.com/fix-wi-fi-problem-android/
    Also a suggestion here for 8 Series but some of the suggestions may crossover to other OnePlus series phones.
    https://forums.oneplus.com/threads/my-findings-of-the-5-ghz-wifi-connection-issue.1221263/
  6. ironass
    Lollipop Nov 23, 2020
    ironass , Nov 23, 2020 :
    This OxygenOS 10.3.0 was released in December 2019, nearly a year ago.
    Perhaps you should try updating to the newest firmware, OxygenOS 10.3.6...
    OxygenOS 10.3.6 for the OnePlus 6 and 6T
  7. ironass
    This firmware has been updated 6 times since this release and some of those updates contained camera improvements.
    There is no point in complaining about a nearly year old firmware and camera as it could already be fixed in later updates.
  8. Caoimhín
    OnePlus 9 Series Expert Community Expert Nov 23, 2020
    Caoimhín , via OnePlus 6T , Nov 23, 2020 :
    If you are still on 10.3.0 then there is no point going on about the camera. It's old software, many improvements have been made since and a lot of bugs squashed.
    Have you tried 10.3.5 or 10.3.6 to check if there are any improvements in the camera for you. If not then you argument about the camera is mute and pointless.
    ironass likes this.
  9. Caoimhín
    Have seen your old threads. Replied to some as well. But you say software is updated, is that just camera software or what build are you on. If you are on a higher build than 10.3.0 then you are posting in a redundant thread and should post in the thread meant for the build you are on.
    Which build of OOS are you currently on.?
  10. ironass
    I am confused! :confused:
    Today you are posting about camera issues with OxygenOS 10.3.0 whereas yesterday you started a thread about camera issues on OxygenOS 10.3.6. See..
    [OnePlus 6 Rear Camera] lack issues while shooting
    So... which is it?
    Have you done as our Community Expert, @Bouncer71, suggested in reply to your thread?
    Alternatively, are you just randomly posting in any old thread that suits you? :rolleyes:
    Bouncer71 and Caoimhín like this.
  11. Caoimhín
    Just for info, the camera software uses the Android system to work correctly, that system has been updated 6 times since 10.3.0. So stating you have latest Software for Camera is pointless as the Android subsystem has been updated to cope with software and apps ever since.
    I understand, you are having a rant about software that is 6 generations back. Which gives you no leg to stand on, as its not supported due to it being superceded 6 times up to 10.3.6 now. So you are now going to be talking to an echo chamber, you will only be able to hear yourself from now on, and all on UNSUPPORTED Software.
  12. pjs02024
    Donut Apr 8, 2021
    pjs02024 , Apr 8, 2021 :
    my oneplus 6 got overheated and battery draining faster, any solution plz
  13. Caoimhín
    OnePlus 9 Series Expert Community Expert Apr 8, 2021
    Caoimhín , via OnePlus 6T , Apr 8, 2021 :
    Check the links below for suggestions and more details on Battery life and Heat issues.
    Battery analysis and battery drain trouble solving by @Swejuggalo
    https://forums.oneplus.com/threads/battery-analysis-and-battery-drain-trouble-solving.1413430/
    Battery Facts by @TheMystic
    https://forums.oneplus.com/threads/battery-facts.995140/
    Guide to lower Battery Drain.
  14. RamMothe
    Gingerbread Apr 9, 2021
    RamMothe , via OnePlus 6 Mirror Black , Apr 9, 2021 :
    Check your battery health and I think it's time to replace it with new one in oneplus store for 500₹ only. And about heat we can to nothing.
  15. pjs02024
    Donut Apr 9, 2021
    pjs02024 , Apr 9, 2021 :
    ok bro, thnks
  16. pjs02024
    Donut Apr 9, 2021
    veru helpful, thnks
  17. E1530065726170
    Eclair Apr 9, 2021
  18. chiluveriraj
    Eclair Apr 10, 2021
