732
OxygenOS 10.3.0 for the OnePlus 6 and 6T
  1. Saurabh_Bhuradia
    Cupcake Dec 20, 2019
  2. KirillFry
  3. Jayesh Haryani
    krakera likes this.
  4. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Dec 20, 2019
    Liehjan , Dec 20, 2019 :
    Read the first post above yours!
    Caoimhín likes this.
  5. sidrocks316
    Froyo Dec 20, 2019
    sidrocks316 , via OnePlus 6 , Dec 20, 2019 :
    everyone who wants to update . just download oxygen os updater app and update your device. it is totally safe . i have been doing this since oneplus 2
    Caoimhín and srikanth.s like this.
  6. H1554975893188
  7. madhavanbe
    Donut Dec 20, 2019
  8. Kim_Akhmetov
    Gingerbread Dec 20, 2019
  9. prasad9989
  10. E1539186364805
    E1539186364805 , Dec 20, 2019 :
    its hanging every time after upgrade to android 10
    heating also high from screen, battery backup fast charge issue, search issue in settings (slow).
    overall system working very slow compare to android 9 in OnePlus 6
  11. I1530784949629
  12. Sighn
    Sighn , Dec 20, 2019 :
    I had that problem. I cleared cache to sort it.
  13. Sighn
    It can't cause data loss and that's due to one big reason: the app doesn't update. It's merely a downloading tool.
    OP's own updater will perform the update or, if your phone is rooted, TWRP will.
  14. DrHarry
    Eclair Dec 20, 2019
  15. Kim_Akhmetov
    Kim_Akhmetov , Dec 20, 2019 :
    your problems with oxygenOS are individually on your device only, maybe a full reset will help you, or you need to use tools oneplus, because of a set of multiple errors, resetting to factory settings does not always help. I had only one problem with using OnePlus 6, after the update I independently switched the vibration response from small to medium and this was fixed after the next patch, and this is the only problem for 6 months after buying the phone. Turn off not many mobile phone manufacturers that release updates with this regularity, and with such careful attention to its users.
  16. Antoine L
    Antoine L , via OnePlus 6 Silk White , Dec 20, 2019 :
    we don't care man. gosh that isn't useful to say this. everyone is waiting there are 78 pages of those similar messages. that's a staged rollout just wait!
  17. H1554975893188
    H1554975893188 , via OnePlus 6T , Dec 20, 2019 :
    Before installing 10.3.0 I flashed 9.0.17 in fastboot mode. I know what I say and what I do.
  18. MALU8484
    Eclair Dec 20, 2019
