282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. drl431
    Community Hero 2020 Jan 23, 2020
    quequacio likes this.
  2. somu1795
    Froyo Jan 23, 2020
    Nk_Vamsi likes this.
  3. Ihor_Syrota
    Froyo Jan 23, 2020
    Ihor_Syrota , Jan 23, 2020 :
    So, I don't get it, why it's impossible to send updates for both devices in same time?
    Ricanstyle and Sergiy_Koshyn like this.
  4. Artemus.
    Artemus. , Jan 23, 2020 :
    Different internals.
    Ricanstyle, drl431 and ironass like this.
  5. AnonymousWP
    The Lab - OnePlus 7 Pro Reviewer Jan 23, 2020
    AnonymousWP , Jan 23, 2020 :
    Well, no, but I can understand why they roll it slowly: because of bugs in previous builds.
    Ricanstyle, drl431 and pvilarinho like this.
  6. Caomhin
    OnePlus 9 Series Expert Community Expert Jan 23, 2020
    Caomhin , via OnePlus 6T , Jan 23, 2020 :
    You can update the Google Playstore System Update from Settings, Security and Lockscreen to January 2020 update. However you will need to update Playstore App first, had a previous version of Playstore App and it kept Failing on the Google Play System update.
    Works fine if you install the update below for the Playstore App from APK Mirror
    https://www.apkmirror.com/apk/googl...5-59-all-0-pr-291056213-android-apk-download/
    Once done, then go to Settings, Security and Lockscreen, Select Google Play System Update, you can then update to January 2020.
    Ricanstyle and drl431 like this.
  7. at0mixX
    Gingerbread Jan 23, 2020
    at0mixX , via OnePlus 6T , Jan 23, 2020 :
    Check for updates. Update and reboot. Worked for me afterwards.
  8. pvilarinho74
    Ice Cream Sandwich Jan 23, 2020
  9. F_Chandradip_Mukherjee_m
    Gingerbread Jan 24, 2020
  10. Sukh Bal
    Eclair Jan 24, 2020
    Sukh Bal , via OnePlus 6 , Jan 24, 2020 :
    i never receive update on time...
    it's like juggling n shear luck.. to check everyday by going into menu of software update 🥺🥺
    neways
    m waiting for the update patiently .[e]1f609[/e][e]1f609[/e]
    thanks for bringing the update ..
  11. W1549454844437
    Cupcake Jan 24, 2020
  12. Glassertje
    Glassertje , Jan 24, 2020 :
    Finaly the 5Ghz wifi is fixt and connecting very fast. I'm curious if the battery drain is also fix, becourse it had to do whit the wifi. Thank you Oneplus.
    Vikash.Khoiwal likes this.
  13. G_Meng_Xu_niXY
    Eclair Jan 24, 2020
  14. Artemus.
    Community Hero 2020 Jan 24, 2020
  15. Rocchiz
    Rocchiz , Jan 24, 2020 :
    Hi there :)
    First of all, I would like to thank OnePlus for the new update which came quite quick after the 10.3.0.
    Secondly, 10.3.0 release is a very stable one, at least for me as I didn't face any major issues like rebooting, heating issues, battery draining etc..
    The one thing that I frequently face is the fingerprint error when trying to unlock the screen from the "black screen" telling me "Finger moved too fast. Please try again" so I have to double tap the screen to get to the screen containing the other unlocking options configured (like pin code or pattern) and at this screen the fingerprint is back to function normally.
    My third point is all about the Notch option, which I believe will be disappointing for many OP owners who really liked the way it was working in Android 9 (considering myself one of them) and expected a fix in this update but sadly looks like it remains the same.. and please guys stop saying that it's a feature from Google and such stuff, in the end it's all about development and code! OR we need to believe that Google is using some kind of a mysterious programming language or development environment.. and Android 10 is the Alien OS 👽 that came from the space hitting our lovely OnePlus phones. 🤣
    hopefully this will be fixed in the coming update and I'm looking forward to seeing 3 options in the notch display setting representing all the 3 flavours as I can see some peeps likes the new implementation too.
    Thanks everyone & have a good day...
  16. G_SayIDidIt™
    G_SayIDidIt™ , via OnePlus Community App , Jan 24, 2020 :
    Great post! Regarding the notch, I'm totally with you. I use an app called Nacho Notch which works pretty good.
  17. G_SayIDidIt™
    Download Oxygen Updater from the Google Play Store and you will receive a notification when the update is available.
    Sukh Bal and Caoimhín like this.
  18. Nahomagan
    Froyo Jan 24, 2020
  19. Nahomagan
    Froyo Jan 24, 2020
    Nahomagan , via OnePlus 6 , Jan 24, 2020 :
    it just started roll out it'll take maximum of 7days to finish the roll out
