282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. atul_murali1904
    Eclair Jan 24, 2020
    atul_murali1904 , via OnePlus 6T , Jan 24, 2020 :
    There is bug in youtube .Whenever I open youtube after use it gets stuck for while after which I have to. lock n unlock my phone den try den it works fyn.Please look into it .I started experiencing it after rollout of OxygenOS10.3.0
    suraj1595, bjorg18 and Karan_Odedra like this.
  2. saber1203
    Gingerbread Jan 24, 2020
    saber1203 , Jan 24, 2020 :
    On the Pixel 3XL with A9 the notch hiding was exactly the same, push the icons down and make the notch black, nothing really changed on A10 except that OnePlus decided to be lazy and not put effort in hiding the notch in a proper way like on A9, they chose to use the same crappy way of hiding it like on the pixel by literally robbing you out of real screen estate
  3. Aryaraj Singh
    Froyo Jan 24, 2020
    Aryaraj Singh , via OnePlus 6 , Jan 24, 2020 :
    Okay highly skilled developer.
  4. Sheikh_Rafiq_
  5. pankaja92
    Cupcake Jan 24, 2020
  6. Karan_Odedra
    Froyo Jan 24, 2020
    Karan_Odedra , Jan 24, 2020 :
    Yes, faced the same issue. Restarted it and worked fine.
  7. Pankkajarora
    Pankkajarora , via OnePlus 6 , Jan 24, 2020 :
    This OTA will have a staged rollout. The OTA will be received by a limited number of users today and will have a broader rollout in a few days after making sure there are no critical bugs. Using VPN to download this build might not work as the rollout Is not based on regions and is randomly pushed out to a limited number of devices.
    Relax and take a deep breath, we're not going to receive it anytime soon.
    Ashwinkumar989 likes this.
  8. U1578507204493
    U1578507204493 , Jan 24, 2020 :
    After updating to 10.3.2 my phone started hanging and wide space is available so that is not a issue .... every app is hanging...when we were talking on Bluetooth headphones my phon automatically catched phone instead Bluetooth ..... please help I never expected that from my favorite one plus
  9. NIK3SH
    Froyo Jan 24, 2020
    NIK3SH , Jan 24, 2020 :
    Believe me. You're lucky.
    At the point you upgrade to this 10.X, you'll start hating your device for sure...
    EPICOnion and E1545974892602 like this.
  10. alex1220
    alex1220 , via OnePlus 6 , Jan 24, 2020 :
    actually i have downgraded my phone from android 10. tried 2 builds and then went back. 3rd build was 10.0.3.0. didn't bother updating. and now this 10.0.3.1.. same change log from past 3 builds. they say it will fix bugs but it won't. and this quality is called cheating which most payboys don't agree with.
  11. saber1203
    Perhaps you like being complacent, but removing a practical solution to a problem and putting a half assed one on top of it seems rather backwards, execution wise I reckon it wouldn't take much to add it back, but given they didn't even bother including it initially you can tell they didn't care, I suppose nowadays leniency is the name of the game for OnePlus and it's loyal white knights
    nonrumor, suraj1595 and Abhilash SP like this.
  12. Phanilkumar
    Froyo Jan 24, 2020
  13. Aryaraj Singh
    Froyo Jan 24, 2020
    They didn't implement it initially because it is indeed a "half assed" implementation. Google has been making it harder and harder to implement hide the notch implementation. But because of the outrage caused due to it's removal, they added this. It is not possible to implement it the way it was earlier. With each iteration of Android, the quality of implementation has deteriorated.
  14. Vinay_NS
    Vinay_NS , via OnePlus 6 , Jan 24, 2020 :
    just an observation in A10.. it's so dumb to that we have to put the notification to high priority to get the icon to be displayed on notification bar.. on A9 it was fine..
    for instance i have a thrid party music player and the icon never appears unless i set the notifications of that app to high priority.. and that's not the worst part, every time I play or pause a song a notification sound is played.. it's so annoying..
    am i the only one who is annoyed by this?
    _dp_ and echelon9797 like this.
  15. saber1203
    While that might be true for the AOSP version, OnePlus is free to modify the code and implement their way of dealing with the notch just as they did with A9, proof of concept is that you can use the settings database editor to enable the old way of hiding the notch, only problem is that it's buggy in some apps including third party ones which is not Google's fault, but OnePlus' for not investing the proper time to fix it
    Rocchiz likes this.
  16. sanjey sniper
  17. CNSKnight
    CNSKnight , Jan 24, 2020 :
    Anyone have a suggestion?...
    I had OP6T_O₂_BETA_33 and just downloaded OnePlus6TOxygetn_32_OTA_042 but cannot install, getting message "Local upgrade The version of your selected package is lower...downgrading is not allowed."
    Meantime, my hotspot throughput is still horrendous!
  18. CNSKnight
  19. echelon9797
    Froyo Jan 24, 2020
    echelon9797 , via OnePlus 6T , Jan 24, 2020 :
    I second this
    _dp_ likes this.
  20. BuntyBadoni
    Eclair Jan 24, 2020
