282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 3, 2020
    Caomhin , via OnePlus 6T , Feb 3, 2020 :
    Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    K1580238753079 likes this.
  2. Caomhin
    Because this is OOS, and you are trying to update over Chinese version, HOS Beta.
    Check if @ironass has a solution for you.
  3. Parth0707
    Donut Feb 3, 2020
    Caoimhín likes this.
  4. kouzelnik3
    Ice Cream Sandwich Feb 3, 2020
    kouzelnik3 , Feb 3, 2020 :
    So I should be able to flash Beta 5 OOS once released over H2OS, is it correct?
    And I will check him but dunno what I am looking for :D
  5. sivaraman.sony@g
    Eclair Feb 3, 2020
    SurajPrakash2210 likes this.
  6. Caomhin
    That could not be guaranteed, as they are essentially the same OS, however Chinese HOS may have slight regional differences within the OS.
  7. Bhavana15
    Cupcake Feb 3, 2020
  8. dm00389731
    Honeycomb Feb 3, 2020
  9. ironass
    Lollipop Feb 3, 2020
    ironass , Feb 3, 2020 :
    You can either use the OxygenOS full downgrade firmware listed, here...
    https://forums.oneplus.com/threads/...thread-for-op6-t.1117217/page-2#post-20885630
    Alternatively, you can use the OnePlus 6 MSMDownloadTool from, here...
    https://forum.xda-developers.com/oneplus-6/how-to/tool-msmdownloadtool-v4-0-international-t3798892
    Both of these will of course, wipe your phone and return it to a stock Android 9 OxygenOS firmware and you will need to upgrade from there.
    If you stay on OxygenOS stable, you will need to install the full version of stock OxygenOS 9.0.9 before moving to Android 10 stock.
    If you choose to move to Open Beta, you will need to install the full version of Open Beta 2 before moving to Open Beta 4.
    (The above links DO work. If you cannot open them using the OnePlus Community app, switch to your Google Chrome browser)
  10. kouzelnik3
    But when I was able to upgrade over OOS to H2OS, it should be possible vice versa. Or am I wrong? :/
  11. Caomhin
    No point repeating your issue so, unless you become proactive about fixing the possible hardware issue, or maybe possible software issue,. Who knows if you submit it often enough to feedback you might get an answer.
    Report a Bug
    Feedback tool
    https://forums.oneplus.com/threads/feedback-tool-lets-improve-oxygenos-together.1021893/
  12. Prithiv995
    Cupcake Feb 3, 2020
    Prithiv995 , via OnePlus 6 , Feb 3, 2020 :
    After updating to the lastest version. when I'm calling from apps it's showing ongoing call in notification even after I'm disconnected the call.
  13. dm00389731
  14. Amey93
    Froyo Feb 3, 2020
    Amey93 , via OnePlus 6 , Feb 3, 2020 :
    Try not to update to Oxygen os 10. It is nowhere near stable. There are many issues, to name the few....Screen wakes up when wrong finger is used for unlocking...Press and hold any icon in the drawer you will see the lag...Shelf gets stuck and cannot scroll...
  15. ironass
    ROLL-BACK FROM ANDROID 10 TO ANDROID 9
    If you feel that you simply cannot live with the current version of Android 10 on your phone and would like to roll-back to the latest version of Android 9 and wait for Google and OnePlus to bring out a later version of Android 10... here's how.
    (TOP TIP: Since downgrading from Android 10 to Android 9 will wipe your phone, why not do a Factory Data reset, on your existing Android 10 first and check out if your issues persist.)
    You will need to use the OnePlus roll-back firmware which will wipe your phone and downgrade you to Android 9, stock OxygenOS.
    See downloads and instructions for both OnePlus 6 & 6T, rollback firmwares...
    [GUIDE] Rollback/downgrade from OOS Android 10/Q to stable 9/Pie
    You can then download the latest version of Android 9 stock Oxygen OS from here to upgrade to the most recent Android 9 release for the 6 & 6T by using Local Upgrade on the phone and the instructions provided. You can then restore your apps and settings.
    iamrj, lukilaki, drl431 and 2 others like this.
  16. dm00389731
    dm00389731 , Feb 3, 2020 :
    i download this package but in local update....it shows downgrading is not allowed because of bootloop
  17. Caomhin
    I have seen it work in the past if one build date is higher then the old version, this will always work for OOS to OOS. But there may be something regional specific within HOS Beta preventing the OOS installation.
    Also check the build dates on the different versions.
    Artemus likes this.
  18. ironass
    Which package are you referring to?
    Artemus and Caoimhín like this.
  19. dm00389731
  20. dm00389731
    the same version in the link you provided
