282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. ten_piseth
    Froyo Feb 4, 2020
    ten_piseth , via OnePlus 6T , Feb 4, 2020 :
    than what can i do if i don't want to delete my data,and fix this problem?
  2. Artemus.
    Community Hero 2020 Feb 4, 2020
    Artemus. , Feb 4, 2020 :
    Unfortunately, that's the only way to fix it AFAIK. I've done it and have had zero issues afterwards. You can easily back up your stuff to either Google Drive (I think 15 gigs is the limit for free) and Photos which will still be accessible post-format.
    drl431, Caomhin and ten_piseth like this.
  3. Alex Sem
    Gingerbread Feb 4, 2020
    Alex Sem , Feb 4, 2020 :
    [QUOTE = "Jamze, post: 21310384, member: 552573"] Вчера было загружено множество обновлений приложений Google, включая Drive, и мои резервные копии снова начали работать 👍🏻 Не знаю, почему, но они запускаются автоматически и завершаются сейчас.
    Хотя экран настроек резервного копирования по-прежнему выглядит по-другому, без учета всех резервных копий, перечисленных ниже 🤔 [/ QUOTE]
    Hey. have not talked for a long time). what version of google drive do you have now?
    Jamze and Caomhin like this.
  4. ten_piseth
    Froyo Feb 4, 2020
    thanks for advice,but still can't do that some data in app like message, photos, video hard to backup.
  5. Artemus.
    That's why I suggested Google Photos. It backs up your photos and videos just fine. Messages, though, you might be out of luck without root.
  6. G_Saffat_Khondaker_fQYP , via OnePlus 6 , Feb 4, 2020 :
    The option to make my Gmail app dark themed is fine now for some reason. is anybody else having this issue? I also constantly get a notification saying that Android Q is "handling theme" that just pops up for no reason. I'm using a OnePlus 6
  7. suresh9890
    Eclair Feb 4, 2020
  8. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 4, 2020
    Caomhin , via OnePlus 6T , Feb 4, 2020 :
    Whole thread on Handling Theme issue here.
    https://forums.oneplus.com/threads/handling-theme-notification.1175515/
    Gmail dark mode is a Google server side issue. Thread on it below.
    https://forums.oneplus.com/threads/gmail-dark-mode-disappear.1178814/
    Search is your friend.
    Sahilk0369 and Artemus. like this.
  9. Caomhin
    it is a Staged Random Rollout, so if you don't see it via OTA, you may need to do it via 3rd party app Oxygen Updater from the Playstore.
    In Oxygen Updater settings, you can set the update method to incremental if you are already on 10.3.0, if you are on any earlier version to this, set update method to full update.
    Artemus. and ironass like this.
  10. pksivaprakash
    Eclair Feb 4, 2020
    pksivaprakash , via OnePlus 6 , Feb 4, 2020 :
    Brightness level has been decreased a lot...i have to keep it to 70% above in indoor lighting condition... anyone having this kind of issue or i am the one facing the issue............any solution to resolve????
  11. Caomhin
    It will update with no data loss as 10.3.1 is a newer build.
    However you will have to install the full 10.3.1 update, as it won't work with incremental over Beta 4. Incremental update will only work from Stable 10.3.0 to 10.3.1
    Artemus., sharma75 and ironass like this.
  12. Deactivated User
    Feb 4, 2020
  13. MikeMp
    Honeycomb Feb 4, 2020
    MikeMp , via OnePlus 6 , Feb 4, 2020 :
    No. you will be fine. no data loss. but if you have something in the lockbox, better back that up. i just did so hours ago, and no rest.
    Caomhin likes this.
  14. G_Huzaifa_Shahbaz_
    Cupcake Feb 4, 2020
  15. Caomhin
    Check post 6 up from yours. [e]2b06[/e]️[e]2b06[/e]️🙄🙄
    Artemus. likes this.
  16. G_Huzaifa_Shahbaz_
    Cupcake Feb 4, 2020
    Caomhin likes this.
  17. Amit_Dhar
    Donut Feb 4, 2020
    Amit_Dhar , via OnePlus 6 , Feb 4, 2020 :
    what about One Plus 6 beta update? when the next update will come! so many bugs in every beta updates.. it seems like android 10 is not made for one plus 6/6t Beta users..
    G_Huzaifa_Shahbaz_ likes this.
  18. Caomhin
    Amit_Dhar
    what about One Plus 6 beta update? when the next update will come! so many bugs in every beta updates.. it seems like android 10 is not made for one plus 6/6t Beta users..​
    Beta queries belong in the Beta 4 thread.
  19. MelficeMoon
