282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 4, 2020
    Caomhin , via OnePlus 6T , Feb 4, 2020 :
    Just install 10.3.1, it will replace 10.3.0 completely.
    java007md and ironass like this.
  2. ReflexGravity
    Donut Feb 4, 2020
    ReflexGravity , Feb 4, 2020 :
    WiFi disconnection for 5Ghz isn't fixed after 10.3.1 update. It still randomly disconnects.
    kaihp likes this.
  3. Caomhin
    That's a new feature of Android 10
  4. Caomhin
    try resetting the WiFi, see if this fixes the issue.
    Settings, System, Reset Options, Reset WiFi
  5. Caomhin
    Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
  6. JAGADISH BHATTA
    Jelly Bean Feb 4, 2020
    Caomhin likes this.
  7. Caomhin
    it is a Staged Rollout, so if you don't see it via OTA, you may need to do it via 3rd party app Oxygen Updater from the Playstore.
    In Oxygen Updater settings, you can set the update method to incremental if you are already on 10.3.0, if you are on any earlier version to this, set update method to full update.
  8. rc075
    Cupcake Feb 4, 2020
    rc075 , Feb 4, 2020 :
    10.3.1 is now available for OnePlus 6 via oxygen updater app.
    Caomhin likes this.
  9. M1541385385528
    Cupcake Feb 4, 2020
  10. landov
    Gingerbread Feb 4, 2020
    landov , Feb 4, 2020 :
    Ohooo...Gmail dark theme option is suddenly back.
    Im on OS 10.3.1, OP6
    bramgoodwin likes this.
  11. Muhammad_Kashif_bahl
    Honeycomb Feb 4, 2020
    robin143 likes this.
  12. ManishSoni07
  13. aseferian
    Froyo Feb 4, 2020
    aseferian , Feb 4, 2020 :
    The digital clock option in the ambient display went away for some reason. Otherwise working fine for me. Those worried about the lack of a changelog can see it in the updater app.
  14. U1551473542284
    Cupcake Feb 4, 2020
    U1551473542284 , via OnePlus 6T , Feb 4, 2020 :
    Thanks heaps.
    Iwas able to clear cache /data for all them only thing was the Google play system update wasn't Jan 20 instead 1 Dec 2019 but it said it was up to date so I guess I'll try it and find out.
  15. Muhammad_Kashif_bahl
    Muhammad_Kashif_bahl , via OnePlus 6 , Feb 4, 2020 :
    This Oxygen OS10.3.1 update change my WiFi MAC Address. Is it possible...???
    i have update through oxygen updater...??
    also facing battery drain issue...!!!
  16. Muhammad_Kashif_bahl
  17. Muhammad_Kashif_bahl
  18. Muhammad_Kashif_bahl
  19. 18VK
    Froyo Feb 4, 2020
    18VK , via OnePlus 6T , Feb 4, 2020 :
    many bugs are also present in 10.3.1 worst performance by the OnePlus [e]1f62d[/e] unnecessary notification and blank space while opening the hidden space
  20. NoobRK
    Cupcake Feb 4, 2020
