282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Ambidan87
    Cupcake Feb 6, 2020
    Ambidan87 , via OnePlus 6T , Feb 6, 2020 :
    ok thank you because I tried one link and it said jar at the end I can't open it . do you know if I'll be able to still downgrade to 9 of I used the oxygen updater.. cause that didn't help either . so this is my last resort.
  2. JAGADISH BHATTA
    Jelly Bean Feb 6, 2020
    JAGADISH BHATTA , Feb 6, 2020 :
    France,Germany and Canada
  3. FaleshC
    KitKat Feb 6, 2020
    FaleshC , Feb 6, 2020 :
    Germany should have definitely worked. it worked for me.
    i used turbo vpn btw.
    mayrsona likes this.
  4. L1531904290108
    Cupcake Feb 6, 2020
  5. FaleshC
    KitKat Feb 6, 2020
    you do need to remove that .jar
  6. Ambidan87
    Cupcake Feb 6, 2020
    I'm gonna download it on my PC and transfer it via USB if I can & see if that works because I can't find my files in my internal storage
  7. Tee_Eee_Bee
    Ice Cream Sandwich Feb 6, 2020
    Tee_Eee_Bee , via OnePlus 6T , Feb 6, 2020 :
    Ambidan87
    ok thank you because I tried one link and it said jar at the end I can't open it . do you know if I'll be able to still downgrade to 9 of I used the oxygen updater.. cause that didn't help either . so this is my last resort.​
    Just need to rename the file to remove the .jar and make sure the file is in the root directory
  8. ironass
    Lollipop Feb 6, 2020
    ironass , Feb 6, 2020 :
    Ensure that the downloaded downgrade firmware is moved to the /root directory of your phone by using your phone's File Manager to cut and paste it and if the file name ends in .zip.jar, use the File Manager to edit off the .jar before going to... Settings > System > System updates > Menu (cog wheel) > Local upgrade and installing the downgrade from there. This will of course, wipe your phone.
    You can then download the latest version of Android 9 stock Oxygen OS from here to upgrade to the most recent Android 9 release for the 6 & 6T by once more, using Local Upgrade on the phone and the instructions provided. You can then restore your apps and settings.
    (The above links DO work. If you cannot open them using the OnePlus Community app, switch to your Google Chrome browser)
    Caoimhín and Ambidan87 like this.
  9. Ambidan87
    Cupcake Feb 6, 2020
  10. ironass
    See my post above yours.
    drl431 likes this.
  11. Y1547161782974
    Froyo Feb 6, 2020
  12. JAGADISH BHATTA
    Contact hike developer to fix issue
  13. JAGADISH BHATTA
    It could be issue with your network provider or network is congested in your location contact your network operator first slow network connection are generally related to network providers
  14. Ambidan87
    Cupcake Feb 6, 2020
    I've weeded out all the simple things 1st . and it's none of those issues . and never had Been an issue before ten update . I have no internet connection.
  15. Ambidan87
    Cupcake Feb 6, 2020
    yes I just can't seem to edit the jar ! I'm doing something wrong and I'm no expert at this .
  16. ironass
    Y1547161782974 and Artemus like this.
  17. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Feb 6, 2020
    Artemus , Feb 6, 2020 :
    You might be better off resetting the phone.
    drl431 likes this.
  18. Ambidan87
    Cupcake Feb 6, 2020
  19. Artemus
    Downgrading will do the exact same thing, just FYI.
    drl431 likes this.
  20. Ambidan87
    Cupcake Feb 6, 2020
