282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Abhilash.D
    Eclair Feb 8, 2020
    Abhilash.D , via OnePlus 6 , Feb 8, 2020 :
    Hi everyone, just now received this update for my OP6.. and pls suggest can i proceed and install ..?? anyone opy user pls suggest..
  2. firstdown80
    Cupcake Feb 8, 2020
    firstdown80 , Feb 8, 2020 :
    Each time I was offered the 10.3.0 update I ignored it and decided to wait for 10.3.1. Going from 9 to 10.3.1.
    Finally was offered 10.3.1 last night, before I starting the update I powered down the phone, cleared the cache, reboot and update.
    Did not touch the phone all night, looks to be functioning fine so far.
    Wipe Cache:
    -Turn off your device.
    -Press and hold the Volume down and Power button at the same time.
    -When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    -At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    -Tap English or whatever is your language preference
    -Tap Wipe data and cache.
    -Tap Wipe cache.
    -Tap Yes to continue.
    -Tap Reboot to restart the phone.
    java007md likes this.
  3. SurajPrakash2210
    Cupcake Feb 8, 2020
    SurajPrakash2210 , via OnePlus 6T , Feb 8, 2020 :
    Hey everyone, got the update last night.
    Anyone facing the issue of not being able to select images from gallery to be sent on whatsapp.
    If so, is there any solution?
    Thanks.
  4. rHITkM
    Honeycomb Feb 8, 2020
    rHITkM , Feb 8, 2020 :
    Yes you are right ,Thanks @Jamze for your help and I have already raised feedback regarding this issue when OOS 10.3.0 was received on 8 Dec 2019.
    Thanks to you @Caomhin As you have suggested I talked to OnePlus and they have understood and will escalate this ISSUE OF ( VIBRATION ON DOUBLE TAP TO WAKE SCREEN ) to the concerned team and it will be resolved in next OTA UPDATE.
    Attaching ss
    P1577214451135 and Jamze like this.
  5. TinyGreen
    Cupcake Feb 8, 2020
    TinyGreen , Feb 8, 2020 :
    BASIC FUNCTION STILL MISSING! When selecting a word in a browser or text editor like note apps and dragging the cursor to the top or bottom of screen, the page doesn't scroll, not allowing to select long text.
  6. Kasu Ropes
    Cupcake Feb 8, 2020
    Kasu Ropes , Feb 8, 2020 :
    I have a problem with my 1+6.
    After the update, my face recognition is wayyy slower.
    Am I the only one, who has this problem?
  7. Z1581178408429
    Cupcake Feb 8, 2020
    Z1581178408429 , Feb 8, 2020 :
    Hi, just updated to the newest version. Beware! Gallery bug fix worked soo well.. I mean there are no wrongly displayed photos in gallery if there is NOTHING in gallery to display -.- , play store freezes and shuts, my browsers freeze and shuts (brave, firefox even chrome). When allowing to use a "notch" there is weird white line just above the notch (I use dark theme), I have gestures rather than home buttons, but I have taken from me about 3/4 of an inch from bottom of my screen as I type right now... Any suggestions of fixing all that? Otherwise I will factory reset that piece of garbage. I mean I have 28GB of memes still existing on my phone and nowhere to see them.. well done.. great update worth 1700MB of download.. give yourself a tap on the back..ffs
    [Edit] in all that cold fury I forgot to specify: Im on OnePlus 6
  8. G1568095277163
    Cupcake Feb 8, 2020
  9. W1547647137565
    Cupcake Feb 8, 2020
    W1547647137565 , Feb 8, 2020 :
    in adaptive brightness mode there is a problem.. the screen is not dimning at low.. it's stucking on a place ..fix it plz
  10. E1552951885996
    Cupcake Feb 8, 2020
  11. John_W
    Cupcake Feb 8, 2020
    John_W , Feb 8, 2020 :
    I'm finding my phone no longer accepts my fingerprints, I constantly get an error saying 'finger moving too quickly', even if it isn't moving, and I get the same error message when attempting to add a new fingerprint. Very annoying.
    edited to say it's started working again
  12. Trevor.Hawkes
    Ice Cream Sandwich Feb 8, 2020
    Trevor.Hawkes , Feb 8, 2020 :
    I get so sick of people suggesting that, because I have no problems with the update, I'm paid by oneplus to post that information and now you have said that an alternative is that I am ignorant. Well thanks for that.
    I will say this again, I DONT HAVE ANY OF THE BUGS THAT SOME OTHERS APPEAR TO HAVE WITH THE UPDATE.
    I am beginning to wonder if you're all lying and you are being paid to complain or are too ignorant to use you phones successfully.
    I have the 1+1,2,3,5 and 6. In all the years I have been using mobiles including other manufacturers units as well I can say that I have only had three or four update bugs. Why? I don't know. Maybe, just maybe it's because I don't load my phone with social media and game apps and I use the devices for what they are intended, as portable bloody phones. I don't habitually reset or clear caches, I just get the updates, install them and use them.
  13. Wing126
    Eclair Feb 8, 2020
    Wing126 , Feb 8, 2020 :
    Having issues with my hotspot since updating to 10.3.0, unfortunately 10.3.1 hasn't fully fixed the issue for me.
    I have no internet connection when using hotspot. My carrier permits hotspot usage and I've tried using my sim card in another phone and the hotspot worked perfectly.
    I believe the issue is being caused by an APN that appeared after updating to 10.3.0 that I cannot modify.
    I've had my Oneplus 6T for over a year now and my hotspot worked perfectly until 10.3.0.
    Can anyone give me a solution???
  14. fritz3000
    Cupcake Feb 8, 2020
    fritz3000 , Feb 8, 2020 :
    Three things:
    My phone seems pretty slow at times after the update
    I get the strange 'handling theme' notification when I start up my phone
    I get a message from Skype Lite saying 'ungoing call' when I start up my phone, despite not using Skype at all
    Are these known issues? Would be great if they could be resolved.
    D1562381550331 likes this.
  15. D1562381550331 likes this.
  16. D1562381550331
    Cupcake Feb 8, 2020
  17. D1562381550331
    Cupcake Feb 8, 2020
  18. p51d007
    KitKat Feb 8, 2020
    p51d007 , Feb 8, 2020 :
    Update showed up on my device, Friday, Feb. 7th (USA model). Installed, no issues. Stable.
    19TCC62 and A1550387522048 like this.
  19. ironass
    Lollipop Feb 8, 2020
    ironass , Feb 8, 2020 :
    Is yours the T-Mobile (USA) model or the global model?
