282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. JAGADISH BHATTA
    Jelly Bean Feb 11, 2020
  2. X1540794839032
    Eclair Feb 11, 2020
    X1540794839032 , via OnePlus 6T , Feb 11, 2020 :
    Has anybody found a way around with the annoying notification sound during calls?
    If on a call (phone to ear) and an audible app notification comes in, a loud noise is produced which can be disturbing. This applies to app notifications not in SMS from what I have experienced.
    I think it's been reported already. Just looking for any tricks.
  3. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 11, 2020
    Caomhin , via OnePlus 6T , Feb 11, 2020 :
    Try the following to fix the Playstore issue,
    Clear the App info Cache and App info Storage for all 3 items
    Google Playstore
    Google Play services
    Google Services Framework (Search in Setting for this)
    Restart the phone
    See if this rectifies the issue.
  4. Caomhin
    Wipe cache partition
    Turn off your device.
    Press and hold the Volume down and Power button at the same time.
    When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    Tap English.
    Tap Wipe data and cache.
    Tap Wipe cache.
    Tap Yes to continue.
    Tap Reboot to restart the phone.
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️NEXT[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️
    Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    OnePlusSQRT36 and ironass like this.
  5. nagarjuna003
    Gingerbread Feb 11, 2020
    nagarjuna003 , Feb 11, 2020 :
    still iam getting the download option
  6. misshu
    Froyo Feb 11, 2020
  7. Caomhin
    Open Google Play Music and turn off notifications, see if that helps.
    ironass likes this.
  8. Caomhin
    ironass likes this.
  9. misshu
    Froyo Feb 11, 2020
  10. .Sudhanshu. , via OnePlus 6T Mirror Black , Feb 11, 2020 :
    no it doesn't work
  11. Caomhin
  12. Caomhin
    You might have stated that in your previous post, you said Where is it.
    As this is a User forum, you might want to contact OnePlus directly on this issue.
    Please submit your issues directly to OnePlus use the following links to do so.
    Report a Bug
    Feedback tool
    You can contact OnePlus support directly for more information on your issue. Scroll down the page for contact details.
    ironass likes this.
  13. yatish609
    Eclair Feb 11, 2020
  14. sepol1
    Froyo Feb 11, 2020
  15. Caomhin
  16. ROYALASHOK
    Eclair Feb 11, 2020
    ROYALASHOK , via OnePlus 6T , Feb 11, 2020 :
    After updating to the new update Android version 10 my phone is not working well. Is doing a lot of slow work and is facing a lot of problems. Plz release a new update and fix all issues
  17. Caomhin
  18. O1577180072800
    Cupcake Feb 11, 2020
    O1577180072800 , via OnePlus 6T , Feb 11, 2020 :
    The app lock still has issues since android 10 update. App notification comments aren't hidden for those app lock is used upon.
    Is someone else facing the same issue???
