282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Rahul_Chowdhary
    Eclair Feb 11, 2020
    Rahul_Chowdhary , Feb 11, 2020 :
    I updated to the latest 10.3.1 update on my OP6 2-3 days ago. I am unable to update my apps in play store as it says "Error checking for updates". Please fix this problem ASAP. I am unable to update my apps
  2. hruaidiak
    Cupcake Feb 11, 2020
  3. samvijaypraveen
    samvijaypraveen , via OnePlus 6 , Feb 11, 2020 :
    after the new update of OS.. now whenever I am on voice calls the internet connection gets cut.. and only after I finish the call it getting active again... do suggest if any setting changes to be made..
  4. Trevor.Hawkes
    Ice Cream Sandwich Feb 11, 2020
    Trevor.Hawkes , Feb 11, 2020 :
    Goto
    Apps and notifications\,see all apps\Google Play store\ storage & cache,\ clear cache.
    Worth a try.
    Rahul_Chowdhary likes this.
  5. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 11, 2020
    Caomhin , via OnePlus 6T , Feb 11, 2020 :
    Try the following,
    Clear the App info Cache and App info Storage for all 3 items
    Google Playstore
    Google Play services
    Google Services Framework (Search in Setting for this)
    Restart the phone.
    See if this rectifies the issue.
  6. Caomhin
    Reset your WiFi and Mobile Network
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
  7. Trevor.Hawkes
    Many people are having problems but many are not. Some problems also being reported by other manufacturers mobile users after updating to android 10.
    If you are competent and happy to swap versions and deal with problems then update. If not or if your mobile is needed for work or school then don't.
    Basic rule is if your mobile is working well and it is extremely important to you that it is still working tomorrow then don't update. Ever !
    Caoimhín likes this.
  8. sanskar27
  9. NHine
    NHine , Feb 11, 2020 :
    Liking the update.
    A note regarding the notch display - when notch setting is set to hidden the icons drop down below the camera level and the black bar at the top becomes too big. Can they be put back to the top level either side of the camera notch like on the Oxygen 9 version?
    Also, can the dark theme have a setting introduced to automatically turn on/off at sunrise & sunset - in the same kind of way as night mode's blue light filter?
    Kind regards,
    NH
    JAGADISH BHATTA likes this.
  10. ARX007
    Froyo Feb 11, 2020
  11. Sudhanshu Joshi SDD
    Honeycomb Feb 11, 2020
  12. Artemus.
    Community Hero 2020 Feb 11, 2020
    Artemus. , Feb 11, 2020 :
    The new notch prevents burn-in, you'll appreciate eventually.
    What you're asking is "scheduled power off".
  13. deepakrohila81
    Donut Feb 11, 2020
  14. Artemus.
    What about it isn't working?
  15. deepakrohila81
    Donut Feb 11, 2020
  16. deepakrohila81
    Donut Feb 11, 2020
  17. Artemus.
    Turning the phone changes the size of the picture, it's not supposed to rotate.
  18. Caomhin
    Zoom is not a feature of the front camera anymore. Android 10 is a whole new OS. So unless the feature is reintroduced in a later update, stuck with no front camera zoom.
    Artemus. likes this.
  19. Caomhin
    Try the following, see if it helps.
    Wipe cache partition
    Turn off your device.
    Press and hold the Volume down and Power button at the same time.
    When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    Tap English.
    Tap Wipe data and cache.
    Tap Wipe cache.
    Tap Yes to continue.
    Tap Reboot to restart the phone.
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️NEXT[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️
    Just in case there is an App hogging resources, causing lag, Battery drain, reboots or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
  20. deepakrohila81
    Donut Feb 11, 2020
    deepakrohila81 , Feb 11, 2020 :
    Turn on auto rotation of the phone when I play video from YouTube. Then youtube video does not auto rotate after rotating the phone
