282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 11, 2020
    Caomhin , via OnePlus 6T , Feb 11, 2020 :
    Try disable Auto Rotate in phone settings, restart the phone, then re-enable auto rotate, see if that fixes the issue
    Artemus likes this.
  2. Caomhin
    See if this will fix those issues.
    Wipe cache partition
    Turn off your device.
    Press and hold the Volume down and Power button at the same time.
    When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    Tap English.
    Tap Wipe data and cache.
    Tap Wipe cache.
    Tap Yes to continue.
    Tap Reboot to restart the phone.
    ironass, deepakrohila81 and Artemus like this.
  3. deepakrohila81
    Donut Feb 11, 2020
    deepakrohila81 , Feb 11, 2020 :
    I have already tried..
    Caoimhín likes this.
  4. deepakrohila81
    Donut Feb 11, 2020
    i will try...
  5. GauravaNayyarr
    Donut Feb 11, 2020
    GauravaNayyarr , via OnePlus 6 , Feb 11, 2020 :
    please check this for disabled vibration completely.
  6. Mani45op6
    Cupcake Feb 11, 2020
    Gokul7373 likes this.
  7. Vineet5887
    thirudev770 likes this.
  8. dhimanatul
    Donut Feb 11, 2020
    Bhagyesh27j and adi1001 like this.
  9. GauravaNayyarr
    Donut Feb 11, 2020
  10. Jamze
    Ice Cream Sandwich Feb 11, 2020
    Jamze , Feb 11, 2020 :
    The issue the OP raised was the haptic 'buzz' when you double-tap to wake. This doesn't turn that off, unfortunately.
  11. Caomhin
    Clean the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush. Android 10 appears to be a bit more sensitive to connections.
    ironass likes this.
  12. RobertPICCO
    RobertPICCO , via OnePlus 6T , Feb 11, 2020 :
    Hello to all. Since i updated OxygenOS from 9 to 10 on december 2019, a bug appeared. When i'm connected by 5 Ghz wifi on internet (even on 2,4Ghz) , it became impossible to send or receive any phone call or sms. When i'm far from wifi box and not connected, 4G phone network works again. I updated in 10.3.1 few days ago, but nothing changes. Could you help me please ?
  13. cas8180
    cas8180 , via OnePlus 6T , Feb 11, 2020 :
    So a lot of people on here are saying wipe cache. This tends to be an old school method for resolving any type of app crashing or battery drain issues after an OTA. The majority of the time the OTA will wipe cache when and where it is needed.
    As a side note if you use apps like Google photos and have a ton of photos on your phone, and Google backup turned on. wiping the our cache will trigger Google photos to rescan your local storage and attempt to resync any photos stored in the cloud. this process is extremely expensive and will in fact cause a battery drain.
    JAGADISH BHATTA likes this.
  14. Jamze
    So what's the 'new school' method then?
    ironass, Artemus and Caoimhín like this.
  15. Alex Sem
    Gingerbread Feb 11, 2020
    Alex Sem , Feb 11, 2020 :
    [QUOTE = "Caomhin, сообщение: 21325823, член: 1870372"] Входящие, утка и прикрытие .... [e] 1f633 [/ e] [e] 1f633 [/ e] [e] 1f633 [/ e]
    Заявление Oneplus о новой функции Ambient Display. Вы должны согласиться, и это поэтапное развертывание.
    https://forums.oneplus.com/threads/...de-is-rolling-out-to-oneplus-devices.1182069/
    Будьте осторожны с их ... [e] 1f631 [/ e] [e] 1f631 [/ e] [e] 1f631 [/ e] [/ QUOTE]
    Here is a message coming to activate this
    Caoimhín and rHITkM like this.
  16. cas8180
    OP puts out an OTA that's fully qa'd. Doesn't have these issues.
    A more surgical approach is to monitor your battery stats after an update. if you can pinpoint the battery drain, try clearing the storage of that individual app. The built in battery stats may not be enough for this diagnosis. There are 3rd party apps that can offer more granularity.
  17. rHITkM.
  18. Alex Sem
    I do not use google assistant. Promto notification has arrived. for fun, I can activate, but later, now there is no way.
  19. rHITkM.
    rHITkM. , via OnePlus 6 Mirror Black , Feb 11, 2020 :
    Good for you man .
    By the way that msg was not intended for you, I forgot to quote it for the reply to the person who has suggestions for my previous issue with the device .
  20. rHITkM.
