282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Artemus
    Community Hero 2020 Feb 11, 2020
    Artemus , Feb 11, 2020 :
    Is your 6T from T-Mo?
    drl431 and Caoimhín like this.
  2. G1581445623393
    Cupcake Feb 11, 2020
  3. G1581445623393
  4. Artemus
    There's your problem. They have their own updates, meaning the updates here won't do you any good unless you unlock your phone and flash the global ROM.
  5. G1581445623393
    G1581445623393 , Feb 11, 2020 :
    how would I go about that? I had it unlocked to use the AT&T SIM card.
  6. E1577305459520
    Donut Feb 11, 2020
    E1577305459520 , via OnePlus 6 , Feb 11, 2020 :
    I did a downgrade to latest 9.x release after upgrading to 10.3.0, due to some issues. But upgraded my OnePlus 6 to 10.3.1 this past weekend after receiving the OTA upgrade notice, and it's working pretty fine for now, no issues and no changes to battery performance.
    The only thing I'm missing is having the status bar at the notch area when the setting to hide the notch is enabled, but is a minor downside to have the phone updated.
  7. BizSale
    BizSale , Feb 11, 2020 :
    is the going to be an update for the 6T to make it compatible with Visible phone service?
  8. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 11, 2020
    drl431, ironass and Artemus like this.
  9. B1581454876451
    B1581454876451 , via OnePlus 6 , Feb 11, 2020 :
    Installed 10.3.1 a couple of days ago. Beforethe update my oneplus 6 worked fine without any issues.
    After the 10 3.1 update I sometimes get a black screen when using the camera. I cannot attach photos to messangers or WhatsApp. The phone also hangs now and then.
    Strange that the bug fix actually creates bugs.
    Anyone else experience the same issues?
    I1581456703658 likes this.
  10. Artemus
    The whatsapp thing is known already, nothing anyone can do until the beta is publicized..
    drl431 likes this.
  11. I1581456703658
    I1581456703658 , Feb 11, 2020 :
    Yes
    Pic attachment problem see as well as frozen input fields.
    Also app menu search uses still black text on black background.
  12. E1577305459520
    Donut Feb 11, 2020
    B1581454876451
    no issues here. I would recommend you to backup your data and apps, do a reset to factory, then restore your data
    Caoimhín and karya174 like this.
  13. sepol1
    Froyo Feb 11, 2020
    Filip Randjak likes this.
  14. alchemistt
    Cupcake Feb 12, 2020
  15. Skillfulrose08
    Eclair Feb 12, 2020
  16. Tee_Eee_Bee
    Ice Cream Sandwich Feb 12, 2020
    Tee_Eee_Bee , Feb 12, 2020 :
    You could try this:
    1. Clear Storage data of Play Store
    2. Clear Storage data of Google Pay
    3. Clear Cache of Play Services - search for "play services" under Settings -> Apps & Notifications -> See all Apps
    Caoimhín likes this.
  17. pavan.kumar.p
  18. wroane
    Gingerbread Feb 12, 2020
    wroane , Feb 12, 2020 :
    I just got a 6t, the TMobile version. Am I going to get the 10.3.1 update? The Google updater says that I couldn't download it.
  19. Tee_Eee_Bee
  20. wroane
    Wish that I had seen that before I bought it.
