282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. landov
    Gingerbread Jan 24, 2020
    landov , Jan 24, 2020 :
    Stop spamming, pls.
    Ashwinkumar989 likes this.
  2. sanjey sniper
  3. Caomhin
    OnePlus 9 Series Expert Community Expert Jan 24, 2020
    Caomhin , via OnePlus 6T , Jan 24, 2020 :
    If you do update, backup your phone before updating. Then once updated, do a full Delete Data format of the phone to install a fresh installation of whatever version you have update to. This should ensure minimal if any issues. 10.3.1 seems to have ironed out a lot of problems for the minority who had issues.
  4. Caomhin
    drl431 and ironass like this.
  5. Caomhin
    Personally I have not come across any issues, it seems to have fixed many issues that the minority of people had.
    drl431, 3PLΞ8 and ironass like this.
  6. sanjey sniper
    sanjey sniper , via OnePlus 6T , Jan 24, 2020 :
    is battery drain issue fixed?
  7. Majuran thas
    Honeycomb Jan 24, 2020
    Majuran thas , via OnePlus 6 , Jan 24, 2020 :
    Where is the fix for recent switching app? still the bug there
    Bug: when you switching the app constantly using OnePlus gesture, app won't switch to previous used app. instead of it go to a random app
    Caomhin likes this.
  8. M1554312629944
    Cupcake Jan 24, 2020
  9. Caomhin
    As it has only just been released, I am not sure that there has been time to find out, however the amount of people posting with battery issues has reduced drastically. Best to try an see hi you fare out. I will post my current battery stats below.
    Install latest OOS 10.3.1 incremental update just released for 6T, 6 should be showing soon, it is a Staged Rollout, so if you don't see it via OTA, you may need to do it via 3rd party app Oxygen Updater from the Playstore, see if it fixes any issues you may have.
    In Oxygen Updater settings, set the update method to incremental.
    Battery Stats
  10. Caomhin
  11. sanjey sniper
    ok thank-you
    Caomhin likes this.
  12. Caomhin
    With specific information, can you detail what you mean by switching app
  13. Majuran thas
    Caomhin likes this.
  14. Caomhin
    I'll be honest, I have never seen that, have you installed 10.3.1. I swipe up and get a list of recent apps, I can then swipe left to view any of the recent apps and switch between them. What exactly happens when you try this.
    Majuran thas likes this.
  15. Filipendula.
    Filipendula. , Jan 24, 2020 :
    does this solve problems on OP6 when recieve notification i cant interact with it. when i press on notification i press something behind notification. same when i pull down qiuck setting. i need to lock/unlock phone to solve this every time. i have problem with randomly pthone switching to 30fps dor no reason. dint have that problems on oos9
  16. Majuran thas
    In Android 9, swiping in the same detection gave recent app switch between two apps
    example:
    1. web browsing
    2. copy a word and open translate app and get the meaning
    3. swap to go to browser
    4. again found a new word
    5. copy it and swap it for going to the translate app
    I did it all with swapping in the same detection. but now need to swap in the different detection to get the recent app
  17. Caomhin
    Just tried your example and I find I have to paste the word into the translation field and it translates fine, but I do have to copy and paste it. I use Google Translate to do this.
  18. Caomhin
  19. Caomhin
    Hasn't been released for 6 yet, only 6T.
