282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. M1577286560852
    Cupcake Feb 14, 2020
  2. ARX007
    Froyo Feb 14, 2020
    ARX007 , Feb 14, 2020 :
    notification ringtone and SMS ringtone sounds the same despite changing it to different sounds.
  3. P1530665547594
    Eclair Feb 14, 2020
    Srínívas Sñ likes this.
  4. Auristic
    KitKat Feb 14, 2020
    Auristic , Feb 14, 2020 :
    Why? Please be more specific.
    What did you do so far to solve YOUR issue?
    drl431 and Caomhin like this.
  5. P1530665547594
    Eclair Feb 14, 2020
    P1530665547594 , Feb 14, 2020 :
    uninstall the app with all the data cleared and it will help !
  6. falco090
    Froyo Feb 14, 2020
    falco090 , Feb 14, 2020 :
    Really? Notch was working fine on 10.3.0 and the keyboard gap wasn't there on 10.3.0... Very odd.
  7. Caomhin
    KitKat Feb 14, 2020
    Caomhin , via OnePlus 6T , Feb 14, 2020 :
    Mine is a little better, however like I said it depends on apps installed, phone personalisations and many other factors to do with how you use your phone personally. Everyone has different uses for phones.
  8. Caomhin
    KitKat Feb 14, 2020
    Go to the 10.3.0 thread, you will find it has been there since the original release of Android 10. Posts there to prove it.
    drl431 likes this.
  9. Caomhin
    KitKat Feb 14, 2020
    Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of 10.3.1. So you will need to backup your phone.
    After Backing up the phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button,
    drl431 and Auristic like this.
  10. Auristic
    KitKat Feb 14, 2020
    Is it an answer or a statement?
    Caomhin likes this.
  11. M.Shree
    M.Shree , Feb 14, 2020 :
    clear the cache and restart the phone
  12. gtarun1
    gtarun1 , Feb 14, 2020 :
    Hey so I updated the device with 10.3 , I realised that the volume from my bluetooth device has decreased alot, even on full volume it feels like 60% volume before the update
    did anyone else faced the similar issue
    for reference I am using apple airpod with one plus 6
  13. felixtaboas
    felixtaboas , Feb 14, 2020 :
    Hello, I have already seen some more review of it: since this update a fast car charger that I have only normal speed charging .. worked perfectly until this version ... any idea of what to try ?. Thank you
  14. Caomhin
    KitKat Feb 14, 2020
    Try cleaning the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush, Android 10 is a bit more sensitive to connections.
  15. X1540794839032
    Eclair Feb 14, 2020
    X1540794839032 , via OnePlus 6T , Feb 14, 2020 :
    Disable the BT absolute volume and raise the media volume to 100%. it will then work ok. Absolute volume is not working ok in this update especially with car BT.
  16. gtarun1
    yes I have disabled, and volume is 100% but it sounder much lesser then before the update. . @OnePlus need to fix this .. even the call volume is less ha e to switch to phone when gets calls
  17. adi1001
    Honeycomb Feb 14, 2020
  18. Caomhin
    KitKat Feb 14, 2020
    This is not a solution, but a workaround, and you use it at your own risk if you wish to try it. I have not used this, as I don't use Bluetooth headphones.
    I would recommend reading the whole article, as it explains why some Bluetooth headphones have the issues you experience.
    How to Change Bluetooth Audio Codec of Your Android Device
    https://mashtips.com/change-bluetooth-audio-codec-android-device/
  19. Caomhin
    KitKat Feb 14, 2020
    Just in case there is an App hogging resources, causing lag, heating, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    adi1001 likes this.
  20. ARX007
    Froyo Feb 14, 2020
    Anyone?
