282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. felixtaboas
    Cupcake Feb 14, 2020
    felixtaboas , Feb 14, 2020 :
    Hi, the charger has worked perfectly (I use it DAILY) until this update: it is impossible for what you say; something has to be wrong
  2. vikkvikk
    Eclair Feb 14, 2020
    vikkvikk , Feb 14, 2020 :
    latest models are also buggy... they are also in the same boat but a different section I guess.
  3. Jamze
    Ice Cream Sandwich Feb 14, 2020
    Jamze , Feb 14, 2020 :
    There's a flaw in your thinking. As a marketing initiative, this would likely fail, as it would force people to another manufacturer, wouldn't it? If you had a buggy old OnePlus, why would you buy another?
    My Dad's 7T is identical to my 6 on Android 10. Both work fine.
    Caomhin, AtlasHun, Auristic and 3 others like this.
  4. Gokul7373
    Gingerbread Feb 14, 2020
  5. I1550705026001
  6. I1550705026001
    I1550705026001 , Feb 14, 2020 :
    I'm getting these too. Never had it before :/
    Aditya Nerkar likes this.
  7. AmitMohanty
    Eclair Feb 14, 2020
    AmitMohanty , Feb 14, 2020 :
    Not many Apple users migrated to Android when Apple slowed down their phones. And OnePlus is not Apple. It will definitely lose customers to other manufacturers. But there are people who ll stick to OnePlus just because of its clean software experience. But tbh that clean software experience is being very closely matched by other companies who are providing similar package at almost half the price. And who said all marketing initiatives are successful and well thought out
  8. AmitMohanty
    Eclair Feb 14, 2020
    I had the same problem. It was back to normal after a restart. Sounds too simple but it actually worked for me after my first android 10 uodate
  9. ARX007
    Froyo Feb 14, 2020
    ARX007 , Feb 14, 2020 :
    OMG...[e]1f602[/e]... let's see
  10. Gokul7373
  11. Jamze
    Nobody.
    Apple's was a response to ageing batteries on their old phones, throttling done on purpose to prevent unexpected shutdown of the handset. They are being fined for not communicating this. It's inferred this was on purpose so people would be tempted to upgrade the handset.
    I don't think comparing Apple users -> Android as a result is equivalent to Android user -> another Android. Apple users are locked in (or think they are).
  12. Gokul7373
    Gokul7373 , via OnePlus 6T Midnight Black , Feb 14, 2020 :
    Bro i want to downgrade my 6T to Android 9. Can you please help me
  13. ItsRavi25
    ItsRavi25 , via OnePlus 6T , Feb 14, 2020 :
    download android 9 file from oneplus rom website...goto setting >system>check for update>click on gear icon select local upgrade .. select the file and install....
    backup your data...your phone will full format..
  14. ItsRavi25
    factory reset..will solve your problem..or install software
  15. Gokul7373
    The downgrade file from OnePlus rom is a full update file or OBT
  16. ItsRavi25
  17. Gokul7373
  18. ItsRavi25
    Gokul7373 likes this.
  19. Gokul7373
  20. kevinmcintyre09
    kevinmcintyre09 , via OnePlus 6T , Feb 14, 2020 :
    Is it just me, but since this update (where I think I was on OS9 before) I cannot connect to many Google services. Phone gets hot and uses a lot more battery. I have no issue connecting from any other device. It killed my Google pay.
    I have worked for a large phone company, so know the testing that occurs, but there seem to be some major glitches in this release that I am shocked it have been pushed out.
    I am on oneplus 6T, and a OnePlus fan since buying my OnePlus 3T.
    I should say I updated through the phone updater so not side loaded or taking an early version.
    PrakarshX likes this.
