275
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. kvladan
    Froyo Feb 14, 2020
  2. VaibhavAMido
    Eclair Feb 14, 2020
  3. Caomhin
    KitKat Feb 14, 2020
    Caomhin , via OnePlus 6T , Feb 14, 2020 :
    Like I said, it all depends on the apps you use, how you use your phone, there can be many variables. It's impossible to be specific, but you getting 10+ hours SOT is phenomenal, sometimes I might get 9 hours SOT, sometimes 12 hours. It all depends on what I am doing.
    Here's my stats for today, only 30 battery used. So I might get about 10 hours today, maybe more maybe less.
    Kytharsis likes this.
  4. kvladan
    Froyo Feb 14, 2020
    kvladan , via OnePlus 6T , Feb 14, 2020 :
    I only can say that OnePlus 6T have a very, very good battery!!!
    To many of ussers new update to Android 10 damage not only battery .....
    Thank's a all of you and best wishes !!!!
    St_Jacob, Naorahdut123 and Caomhin like this.
  5. Kytharsis
    Marshmallow Feb 14, 2020
    Kytharsis , Feb 14, 2020 :
    Are you gonna tell us what the "bug" is or do you expect a free mind-read session?
    Jamze, drl431, ironass and 1 other person like this.
  6. Caomhin
    KitKat Feb 14, 2020
  7. Caomhin
    KitKat Feb 14, 2020
    Try the following
    Launch Messages
    Three Dots at top right
    Settings
    Advanced
    Notifications
    Other Notifications
    Advanced
    Sound
    For some reason Google messages has it buried in the app settings.
    ARX007 likes this.
  8. ARX007
    Froyo Feb 14, 2020
    ARX007 , Feb 14, 2020 :
    No more options.
  9. mohamedgomran
    Cupcake Feb 14, 2020
  10. Attached Files:
    aakashmaji16 likes this.
  11. Mister_Baker
    Mister_Baker , Feb 14, 2020 :
    Help OnePlus Community!
    Ever since the latest round of updates (10.3.1), I don't get notifications on my OP6 any more. I've checked all sound settings, made sure my phone is allowing notifications and even reset all app notifications however things like WhatsApp, FB Messenger, Text Messages still don't come through when they should. instead I get a load of applications at once.
    Network wise, I'm using both EE in the UK and my home WiFi, my Samsung tablet still gets the notifications and they pretty much always seem to come before I receive them on my phone.
    Is this a known bug, does anyone know of a fix?
  12. Caomhin
    KitKat Feb 14, 2020
    ARX007 likes this.
  13. Caomhin
    KitKat Feb 14, 2020
    Try this way,
    Go into Google Messages App info,
    Click on Notifications
    Click on Other Notifications
    Click on Advanced
    Click on Sound
    This should get you to the ringtone screen for SMS messages within Google Messages app.
    ARX007 and ironass like this.
  14. ohhfem
    ohhfem , via OnePlus 6 , Feb 14, 2020 :
    upgraded to 10.3.1 and GPay is not working? someone can help me pls? and also my device lost certification on Google play store omg. pls help me (OnePlus 6)
  15. Q1581713014848
  16. Caomhin
    KitKat Feb 14, 2020
    So long as the phone is Not a USA TMobile carrier variant, this should work.
    Try the following, Clear the App info Cache and App info Storage for all 4 items
    Google Playstore
    Google Play services
    Google Pay
    Google Services Framework (Search in Setting for this)
    Restart the phone.
    See if this rectifies the issue.
    You can then try to update your Google Play System Update if there is one available in Settings, Security and Lockscreen
  17. Caomhin
    KitKat Feb 14, 2020
    Clear the App info Cache for any individual apps that are hanging.
    Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
  18. ARX007
    Froyo Feb 14, 2020
    I'm using the stock OnePlus messages app. Can I tweak some settings there?
    I don't have google messages
  19. ohhfem
    didn't work and it's all updated on security lockscreen
