282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Alex Sem
    Gingerbread Feb 19, 2020
    Alex Sem , Feb 19, 2020 :
    [QUOTE = "Гиперлакс, сообщение: 21345471, участник: 2632109"] Какая более новая версия - v10.3.1 или Open Beta 4? (Для 6T) [/ QUOTE]
    10.3.1
    Hyperlax and Caomhin like this.
  2. repoo
    Froyo Feb 19, 2020
    repoo , Feb 19, 2020 :
    auto brightness adjustment is a joke now (A 10). Screen i dim for most of time.
    Roby72 likes this.
  3. mhrabhishek
    Froyo Feb 19, 2020
  4. Jamze
    Ice Cream Sandwich Feb 19, 2020
    Jamze , Feb 19, 2020 :
    I can see what it's trying to do, but it can get confused if you have two similar lit environments. For example at night in my car (dark) and at night in my house (also dark). I'm always having to increase the brightness in the car a bit.
    Google could improve this, as they do have info on where I'm using my phone (I'm in my car using Android Auto and it's night time). Hopefully, it will get better.
    You could try resetting adaptive brightness. Under clear storage of Device Health Services.
    Caomhin likes this.
  5. giatros
    Donut Feb 19, 2020
  6. G1536495978989
    Cupcake Feb 19, 2020
    G1536495978989 , Feb 19, 2020 :
    this new update has lots of bugs... every app start lagging specifically Android Auto it is not working in locked screen now which is a feature till last update. phone also getting freezed a lot of time.. network issues is happening after that update.. please fix these..
  7. G1536495978989
    hey even I'm also getting this.. also when I tak on this or shows no so found try again
  8. Caomhin
    Lollipop Feb 19, 2020
    Caomhin , via OnePlus 6T , Feb 19, 2020 :
    They must be, all of those items on that list cause no issues on my 6T. Now maybe some people do have issues, but possibly caused by badly developed apps or apps not Optimized for Android 10, causing conflicts and such, a lot of factors can create issues on a phone.
    After updating to a new OS build. Best to always back up your phone when going to a brand new version such as 8 to 9 and 9 to 10, then nuclear reformat the phone, and only have the OS on it for a while, see how it plays out, then put your apps back on in a sequence, to see what may case issues if any. It's a logical approach.
    When you got your phone first, booted it up, am sure it worked great, then over time you introduced the apps you need and probably some you didn't, but it was a gradual process.
    Well changing OS from 9 to 10 should be treated the same, if there are pitfalls, you will find them easier.
    Logic, my friend, LOGIC.
    drl431 likes this.
  9. Danny_boy
    Danny_boy , Feb 19, 2020 :
    Can you pls tell me how you are getting a decent battery life after the update .. on OnePlus 6t ... Cuz it's been hell for me for the past few days ...
    rushik18 likes this.
  10. Caomhin
    Check further up in this thread page 267 post #5334, I posted details on this 3 days ago. And in previous posts.
  11. Rahul_Chowdhary
    Eclair Feb 19, 2020
    Rahul_Chowdhary , Feb 19, 2020 :
    Great thanks man. it worked !!🙂
    drl431 likes this.
  12. Patrick Trin
    Eclair Feb 19, 2020
    Patrick Trin , Feb 19, 2020 :
    Yes, it's freezing sometimes, so does Chrome
    nuriilhan and PatrickNL like this.
  13. DaRk_ChAoS69
    Eclair Feb 19, 2020
  14. PatrickNL
    PatrickNL , via OnePlus 6 , Feb 19, 2020 :
    same here
  15. Gokul7373
  16. Caomhin
  17. themountaineagle
    Froyo Feb 19, 2020
  18. sumit mondal
  19. sumit mondal
  20. drl431
    Marshmallow Feb 19, 2020
    drl431 , Feb 19, 2020 :
    You will need to contact WhatsApp and ask them to update for Android 10.
