282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Deactivated User
    Jan 24, 2020
    Trevor.Hawkes and ironass like this.
  2. maximus2708
    Gingerbread Jan 24, 2020
  3. N1528734437411
    Cupcake Jan 24, 2020
    N1528734437411 , via OnePlus 6 , Jan 24, 2020 :
    Hi,
    I'm stuck on 10.0.1 and it is quite buggy.
    I couldn't update to 10.3.0 as the local upgrade was zip.jar renaming to .zip wouldn't allow it to successfully update.
    when will the download be on the softer update site please?
    and can we ensure it isn't a .zip.jar or could you update the instructions at the bottom of the support/software update page to work with the file format?
    if none of the above, could someone share the otafsg1 for the OnePlus 6 (and the 6t) please.
    thanks
  4. YasSkiller
  5. reevanshu
    Eclair Jan 24, 2020
    reevanshu , via OnePlus 6 , Jan 24, 2020 :
    Well as of now JioVowifi doesn't support Oneplus phones.
    You can check it on the website.
    Old School likes this.
  6. pappyrahzi
    Eclair Jan 24, 2020
    pappyrahzi , Jan 24, 2020 :
    Any chance they have fixed the games bugs.. Pls let's be guided that the last security updates was December, 1 2019
  7. G_SayIDidIt™
    G_SayIDidIt™ , via OnePlus Community App , Jan 24, 2020 :
    Yes. And that is annoying. It should go to the left and when you want to switch back, you slide to the the left. Why make some on the right and the rest on the left?
  8. G_SayIDidIt™
    Quiter86 likes this.
  9. Jamze
    Ice Cream Sandwich Jan 24, 2020
    Jamze , Jan 24, 2020 :
    I think they want you to do this. The old method does still work, but the last app is no longer always to the right in recents. So to toggle you have to swipe left and right.
    Quickly switch between apps
    You can quickly switch between apps by swiping right over the small line at the bottom of the screen. After you start scrolling through open apps, you can swipe to the left in the same area to go back and forth between apps.
    https://www.cnet.com/how-to/android-10-master-googles-phone-gestures-with-these-8-tips/
  10. Trevor.Hawkes
    Trevor.Hawkes , Jan 24, 2020 :
    If you move the update into the root directory but cannot see it when you try to update it's usually because of this problem. Rename the file to just end in .zip and you will be able to see it using local update.
  11. Arundara
  12. Alessandro_R.
    Eclair Jan 24, 2020
  13. Artemus.
    Community Hero 2020 Jan 24, 2020
    Artemus. , Jan 24, 2020 :
    No. If you're rooted, Gpay will refuse as your phone's been "tampered with" so unless you rooted with Magisk (preferred method), there's a section called "Magisk Hide" that you can use. Otherwise, you're SOL.
    drl431 likes this.
  14. Alessandro_R.
    Eclair Jan 24, 2020
    Alessandro_R. , Jan 24, 2020 :
    In the beta version OB4 before this release I have seen that it was not working even with magisk hide. Are you sure that is enough? It's your experience? Thanks
  15. Artemus.
    Your second option exists then. G Pay is not working for some on beta so it won't matter if it's rooted or not. Contact Topjohnwu to ask about beta.
    drl431 likes this.
  16. Alessandro_R.
    Eclair Jan 24, 2020
    I'm now back to 10.3 and gpay is ok. Just to know if the incompatibility observed with beta is still there.
    I will wait some confirmation before flashing.
  17. Artemus.
    That was fast. o_O
    Alessandro_R. likes this.
  18. den_semenov
    Froyo Jan 24, 2020
    den_semenov , Jan 24, 2020 :
    Oh btw I wonder when OP will add VoLTE profiles for Russia. It's not that funny anymore. Any update that brings this stuff will be nice. Even this exact update would have been nice.
  19. Artemus.
    Russian carriers have to allow it. The phone accepts it but the carrier has to allow it.
    drl431 and den_semenov like this.
  20. den_semenov
    Froyo Jan 24, 2020
    What do you mean? I have Note 9 using VoLTE straight out of the box. With the same SIM-card I use in my OP.
