282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. aakashmaji16
    Gingerbread Feb 19, 2020
  2. samvrant94
    Cupcake Feb 19, 2020
    samvrant94 , via OnePlus 6 , Feb 19, 2020 :
    Hello, I'm using one plus 6 and currently operating android 9. I'm unable to update into android 10 as at the time of downloading at 99% it gets pause and after few seconds it shows downloading failure. This is happening everytime I try to update!
  3. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 19, 2020
    Caomhin , via OnePlus 6T , Feb 19, 2020 :
    What version of 9 are you on, as you need to be on the last update of 9 Pie that was available before updating
    Artemus. likes this.
  4. samvrant94
    Android Version 9 , and Oxygen Os version OP6 O2 BETA_25
  5. Artemus.
    Community Hero 2020 Feb 19, 2020
    Artemus. , Feb 19, 2020 :
    You have to be on at least Beta 2 (think 32?) to update to A10. You are also posting in the stable thread.
  6. Caomhin
    There's your problem right there, you cannot upgrade from Beta 9 version to Stable version 10.
    You need to be on the last version of 9 Pie available for OP6. I believe it was version 9.0.9.
    So you will have to install as a downgrade to Stable 9.0.9, then upgrade to 10.3.1 from there, check @ironass post #7 here, although it mention 10 to 9 stable its the same as for 9 beta to stable 9 Pie.
    https://forums.oneplus.com/threads/how-to-roll-back-to-stable-pie-version-on-oneplus-6.1165323/
    You will need to backup all your Data first, then follow the instruction in the post
    samvrant94 and Artemus. like this.
  7. X1564397409172
    X1564397409172 , Feb 19, 2020 :
    so as you mentioned it is the same case for oneplus 6t there is two builds for oxygen os 10.3.1.
    which file will be the good one from these files :
    -OnePlus6TOxygen_34_OTA_043_all_2001151910_ab93e4deb6c1b.zio from OTA.
    -OnePlus6TOxygen_34_OTA_043_all_2001151910_b0edd817496a413b.zip from oneplus website.
  8. xUciFier , via OnePlus Community App , Feb 19, 2020 :
    Hi team,
    I am facing issues in games like CoDm.
    The game suddenly blacks out and sometimes crashes.
    Faced similar issues with another game as well.
    Seems to be an OS /update issue as do not face the same with other phones.
    Can you please check and confirm if this is a known bug.
    Thanks and Never settle !!!
    bjorg18 likes this.
  9. lyes87
    lyes87 , via OnePlus 6 , Feb 19, 2020 :
    the one from Oneplus website it's better.
  10. Caomhin
    There is a whole thread on it here.
    https://forums.oneplus.com/threads/black-screen-in-call-of-duty-mobile.1176035/
    xUciFier, drl431 and ironass like this.
  11. Artemus.
    What other phones do you own that are on Android 10?
    Caoimhín, drl431 and ironass like this.
  12. nuriilhan
    Cupcake Feb 20, 2020
    nuriilhan , via OnePlus 6 , Feb 20, 2020 :
    stay with android 9 , is better, trust me, i just rollback from 10 to 9, i got my old powerfull phone back
  13. Gokul7373
    Honeycomb Feb 20, 2020
  14. drl431
    Community Hero 2020 Feb 20, 2020
    drl431 , Feb 20, 2020 :
    Yeah, it is odd how much begging there is for security patches. Even the most recent patches are for security holes found 1 or 2 months before. It is best just to avoid risky behavior like side loading apps or clicking on links from unknown sources.
    Caoimhín likes this.
  15. G_Mark_Dunn_JMmj
    Froyo Feb 20, 2020
    G_Mark_Dunn_JMmj , Feb 20, 2020 :
    10.3.1 here. Apps constantly freeze or crash. Especially Google Chrome. Shutter speed on camera is very slow
    D Sai Chakri likes this.
  16. DS_chakri
    Froyo Feb 20, 2020
    DS_chakri , via OnePlus 6 , Feb 20, 2020 :
    bro for me INSTAGRAM is frezzing
  17. georgecga
    georgecga , Feb 20, 2020 :
    I have the 6T and be looking at switching to this device from iPhone. running 10.3.1 and not rooted. Netflix won't work. have to say not a good first step for the switch. is One Plus aware and is there a solution?
  18. samvrant94
    samvrant94 , via OnePlus 6 , Feb 20, 2020 :
    Thanks for the help!
  19. cas8180
    Ice Cream Sandwich Feb 20, 2020
    cas8180 , via OnePlus 6T , Feb 20, 2020 :
    I ran Netflix without any issues on 10.3.1 however I ended up rolling back to 9.0.17 as everything is much more snappier and stable. Also I had several issues with the fingerprint reader not working on 10.3.1. These issues don't exist in 9.0.17
    georgecga and MR.HUNT07 like this.
  20. Gokul7373
    Gokul7373 , via OnePlus 6T , Feb 20, 2020 :
    Then if i am rollback to Android 9 is safe oe not?
