282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Artemus.
    Nougat Feb 23, 2020
    Artemus. , Feb 23, 2020 :
    What apps refresh exactly? You never mentioned that.
  2. Rocky065
    Eclair Feb 23, 2020
  3. Artemus.
    Nougat Feb 23, 2020
    Can you be a bit more specific? If it's a social app, it's supposed to refresh.
    Caomhin likes this.
  4. H1557817058281
    Eclair Feb 23, 2020
  5. P1574958567769
    Cupcake Feb 23, 2020
    P1574958567769 , Feb 23, 2020 :
    Since this update was installed I've experienced a degradation in performance.
    1. the battery drains faster.
    Settings>Battery
    Apps are running normally
    Phone has typical background usage.
    2. the fast charging is not as fast as it used to be.
    3. the "x" icon to close all running apps is missing sometimes.
    Anyone experiencing similiar issues?
    K_deep likes this.
  6. H1557817058281
    Eclair Feb 23, 2020
    H1557817058281 , via OnePlus 6T , Feb 23, 2020 :
    Hi there I have faced the 3rd issue that is the 'x' icon does not come. I cleared the cache of the launcher and then rebooted Since then I have faced no problem with the x icon
  7. arrzaan
    arrzaan , via OnePlus 6T , Feb 23, 2020 :
    Is it advisable to update OxygenOS 10.3.1 via Oxygen Updater app or should we wait for a normal update that is generally diployed in our phone software update section?
  8. P1574958567769
    P1574958567769 , via OnePlus 6T , Feb 23, 2020 :
    Good idea.
    can you send steps!?!
  9. H1557817058281
    Eclair Feb 23, 2020
    Caomhin likes this.
  10. P1574958567769
    I see clear storage.
    should I do that too?
    Thanks for reply.
  11. H1557817058281
    Eclair Feb 23, 2020
    P1574958567769 and Caomhin like this.
  12. anoojlal_rb
    Eclair Feb 23, 2020
    anoojlal_rb , via OnePlus 6 , Feb 23, 2020 :
    okay soo this update is soo buggy my phone restarted out of nowhere yesterday and then it was so laggy and after like 30mins it restarted again so I have to power off the device and clear the cache and the main issue am facing is lagging apps and camera when u close the music player from the notification bar it takes some time for the player to disappear, some other apps does have this lag as well. Android 9 was smooth even when I was on beta there wasn't as many bugs as on stable android 10. idk what oneplus is doing they need to refine their updates. btw is anyone else facing the issue
  13. themountaineagle
    Froyo Feb 23, 2020
    java007md and ACT43277 like this.
  14. U1544636613245
    U1544636613245 , Feb 23, 2020 :
    recently updated to 10 however I realized many small bugs. Some of which are things like the phone model that comes up when you block the camera from face Id scans and it shows you to not block camera. further more anyone notice the unnecessary space between the bottom edge of the phone and keyboard. almost a row worth of space, it takes up space and is not customizable. this update restricted alot of customization even tho it added more.
  15. Cervantes
    Lollipop Moderator Feb 23, 2020
    Cervantes , Feb 23, 2020 :
    Hi
    *"The update thread is a question and comment thread"*
    Please, read the first post
    Use the search engine before opening a new thread
    Thread merged
    Caomhin likes this.
  16. Caomhin
    Lollipop Feb 23, 2020
    Caomhin , via OnePlus 6T , Feb 23, 2020 :
    In the next OOS build, whenever that gets released, no time frame.
  17. Caomhin
    The Keyboard gap has been discussed at length. It's a new Android feature introduced by Google to allow for the new gestures they have.
    As for the Camera, not sure what you mean.
  18. themountaineagle
    Froyo Feb 23, 2020
    themountaineagle , via OnePlus 6T , Feb 23, 2020 :
    security update are must...OP is becoming like others for delivering security update... Which may Become a cause to leave OP
  19. Caomhin
    Artemus. likes this.
