282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Letsgo180
    Donut Feb 26, 2020
    Letsgo180 , Feb 26, 2020 :
    Based on people posts, for some reason resetting it after upgrade is not working. I did reset before upgrading. Not an expert but I read a post where someone suggested to flash it again with 10.3.1. Could work but can't say for sure!
  2. Jamze
    Ice Cream Sandwich Feb 26, 2020
    Caomhin and Kytharsis like this.
  3. fatbuddha001
    Cupcake Feb 26, 2020
    fatbuddha001 , via OnePlus 6T , Feb 26, 2020 :
    Duo calls have frozen video within seconds of the video call bring connected on my OP6T. I can still hear the other person and have conversations without video. All I'm left with is a still picture of the caller with voice only conversations.
    Has anyone else you this problem?
  4. Naveen Rayala
    Donut Feb 26, 2020
    Naveen Rayala , via OnePlus 6T , Feb 26, 2020 :
    Naveen Rayala
    Hi small doubt.for me updated to 10.3.1. and after update i did the factory reset(Erase all data) and install all applications.so is it correct way or any thing missed.beacuse battery SOT for my self is max 5hours after full charge.thanks for the help​
  5. Naveen Rayala
    Donut Feb 26, 2020
    if you don't mind could you share your battery SOT screen shoots for reference.
  6. Letsgo180
    Donut Feb 26, 2020
    there you go..
  7. Caomhin
    KitKat Feb 26, 2020
    Caomhin , via OnePlus 6T , Feb 26, 2020 :
    Try the following to see if it can improve the battery usage.
    As per @Sufwan, Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions again.
    Also just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
  8. Letsgo180
    Donut Feb 26, 2020
    I don't understand , my phone working fine. someone asked me screenshot probably to show how battery performance is after upgrade.
  9. Caomhin
    KitKat Feb 26, 2020
    Sorry replied to wrong person, my bad, apologies for that. [e]1f64f[/e]🙂
  10. Letsgo180
    Donut Feb 26, 2020
    happens. ;)
  11. C1569601707404
    Gingerbread Feb 26, 2020
  12. S1582603065991
    S1582603065991 , via OnePlus 6T , Feb 26, 2020 :
    Sorry but OnePlus has not been able to help me with this issue and I need proper solution otherwise I don't think I will recommend OnePlus to anyone.
    I use 2 different languages everyday.
    one is English and other is MARATHI ( INDIAN LOCAL LANGUAGE) which is in Devnagari script.
    I had an offer from OnePlus to do latest update which I did recently and after update I am left without my second language.
    I did called OnePlus but they did not give me solution that will help to Marathi language back.
    I see all sorts of Crazy square boxes.
    please look for my language requirements or I will consider it was waste of time investing in OnePlus.
    I will wait in anticipation for a concrete results with reply.
    Thanks
    kind Regards
    Puru Desai
  13. Auristic
    KitKat Feb 26, 2020
    Auristic , Feb 26, 2020 :
    Change font from Roboto to Slate or the opposite.
    drl431 and Caomhin like this.
  14. S1582603065991
  15. Auristic
    KitKat Feb 26, 2020
    Customisation.
  16. Trevor.Hawkes
    Trevor.Hawkes , Feb 26, 2020 :
    If I'm understanding you correctly you are saying that at some time in the past you were able to input text in either one of two different languages. I assume that in some way you would select which language you wished to use and keyboard text and screen text would change to suit which language you had selected. Also that after updating you lost that facility.
    ........ NOOOOO !
    Caomhin likes this.
  17. SeeNoWeevil
    SeeNoWeevil , Feb 26, 2020 :
    Since the update my device no longer connects to the audio system in my car. It connects briefly and then disconnects. It keeps cycling this over and over. I've seen it connect once, but unsure why it worked that time. I've done a full factory reset which didn't resolve the issue.
  18. Trevor.Hawkes
  19. Kytharsis
    Nougat Feb 26, 2020
    Kytharsis , Feb 26, 2020 :
    You kinda screwed up the quote here. ;)
    Auristic and Caomhin like this.
  20. Trevor.Hawkes
    Not sure what I did. These word with all those letters in are so confusing.
    Caomhin likes this.
