282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Caomhin
    KitKat Feb 27, 2020
    Caomhin , via OnePlus 6T , Feb 27, 2020 :
    Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of 10.3.1. So you will need to backup your phone.
    After Backing up the phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button
  2. Danny_boy
    Froyo Feb 27, 2020
    Danny_boy , Feb 27, 2020 :
    When I was on 10.0.1 I did a reset ... And after updating I again have to go with all that ... I'm wondering... Do these incremental updates fixes bugs or creates new ones...
  3. Auristic
    KitKat Feb 27, 2020
    Auristic , Feb 27, 2020 :
    Both of course!
    Caomhin likes this.
  4. Caomhin
    KitKat Feb 27, 2020
    Danny_boy
    When I was on 10.0.1 I did a reset ... And after updating I again have to go with all that ... I'm wondering... Do these incremental updates fixes bugs or creates new ones...​
    To be honest, I have never had the issues you experience, it can be down to many factors, Gaming, apps not optimized for Android 10, an App not functioning correctly.
    Yesterday I noticed a spike in my Battery use, found it to be Google Play services, so I cleared the cache from all Google apps, including Playstore, Gmail, Framework, Services, Google App, Chrome, restarted the phone, kinda hit them with a sledgehammer. Working fine since.
    Sometimes an app updates and maybe doesn't play good with older cached data and goes into a tail spin on Battery. Can be any app or apps you may have installed or updated recently.
    I also did a complete Format of the phone before updating to 10.3.1, Battery is excellent since, except for that issue with Google yesterday. Which I fixed.
    Here is my usage and SOT, no Gaming involved though.
  5. Danny_boy
    Froyo Feb 27, 2020
    Damn ... Such battery life I'm getting in whole day of usage with nill percentage left 😂😂😂
    Caomhin likes this.
  6. Danny_boy
    Froyo Feb 27, 2020
    I will do a reset in upcoming days ... But before that thinking of resetting play services and all and then clear cache ... And see hows it responding ... Just one question that ... Do I need to charge phone to 100% and then perform all these steps or at any time.. so that the optimization may hit it
    Caomhin likes this.
  7. Caomhin
    KitKat Feb 27, 2020
    Danny_boy
    I will do a reset in upcoming days ... But before that thinking of resetting play services and all and then clear cache ... And see hows it responding ... Just one question that ... Do I need to charge phone to 100% and then perform all these steps or at any time.. so that the optimization may hit it​
    Have as much Battery as possible, because when you reset it, it will use more Battery for a time after Android finishes the fresh installation, it will be working in the background optimizing apps. Also no harm to set any 3rd party apps to Optimize in Battery Optimization. Just leave the ones you need run in the background for Notifications on Intelligent control.
    Let the phone go through 3 or 4 battery cycles, then check the battery over the days after that and see if it improves. That's what I did, and I just can't drain this battery. Usually about 30% after a full day of use. And I let it on charge all night, even beyond 100%. Been doing that since I got the phone 14 months ago.
  8. D1582561022103
    Cupcake Feb 27, 2020
    D1582561022103 , Feb 27, 2020 :
    checked sim & fine working in the shop. Get home first call same thing & now it wont let me hang up either!! Factory reset maybe?
  9. Caomhin
    KitKat Feb 27, 2020
    Might be the only solution at this stage, although, just before you do. Try resetting the Mobile Network once more. Restart the phone, Ya never know.
    D1582561022103 likes this.
  10. Danny_boy
    Froyo Feb 27, 2020
    Whole night 😳... Dosent it harm or anything like that ?
    Caomhin likes this.
  11. K_deep
    Gingerbread Feb 27, 2020
    K_deep , via OnePlus 6T , Feb 27, 2020 :
    Do a roll back to A9..as i did..till the A10 doesn't make nearby stable by OnePlus
  12. Caomhin
    KitKat Feb 27, 2020
    Nope, never had an issue, so its usually on charge for 6 to 8 hours. Unplug it, and then the Battery just won't drain on me during the day, rinse repeat for the last 14 months, and will keep doing it till the phone is no more, have always done that with all previous phones as well, never had an issue. [e]1f601[/e][e]1f44d[/e]
  13. Caomhin likes this.
  14. nabhan.moideen
    Donut Feb 27, 2020
    Caomhin likes this.
  15. Caomhin
    KitKat Feb 27, 2020
    My 6T, Android 10.3.1 is solid as a rock stable. Battery life better than 9 Pie, and it's as fast as diarrhea out of a camels ***. [e]1f601[/e]
  16. Caomhin
    KitKat Feb 27, 2020
  17. nabhan.moideen
    Donut Feb 27, 2020
    nabhan.moideen , Feb 27, 2020 :
    Not really. Thats all is the changelog for 10.3.2.
    Caomhin likes this.
  18. Caomhin
    KitKat Feb 27, 2020
    Ah right, so it's basically a security update with a couple of bug fixes tossed in for good measure, Nice one [e]1f601[/e][e]1f44d[/e]
    ironass likes this.
  19. Caomhin
    KitKat Feb 27, 2020
    ironass likes this.
  20. nabhan.moideen
    Donut Feb 27, 2020
    yupp, thats right.
    Caomhin likes this.
