282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Caomhin
    Lollipop Mar 4, 2020
    ronaksworld and Artemus. like this.
  2. I1583345638318
    Cupcake Mar 5, 2020
    Caomhin likes this.
  3. nuriilhan
    Cupcake Mar 5, 2020
    nuriilhan , via OnePlus 6 , Mar 5, 2020 :
    You can try rollback to android 9, i did that and works perfect again
  4. H1557817058281
    Eclair Mar 6, 2020
  5. gaurrrav
    Froyo Mar 12, 2020
  6. Flembot95
    Cupcake Mar 12, 2020
    Flembot95 , Mar 12, 2020 :
    Update: I factory reset my phone and all was good afterwards. Just had to reinstall my apps again.
    T1584879144597 likes this.
  7. theanubhavgautam
    Eclair Mar 13, 2020
  8. A1553535144434
    Cupcake Mar 22, 2020
    A1553535144434 , via OnePlus 6 , Mar 22, 2020 :
    The absolute volume of the bluetooth works, but not on all devices. Reset network settings did. 1. With JBL devices - works. 2. With the soundbar LG SK9Y - no. Previously, on android 9 - it worked with LG.
  9. Caomhin
    Lollipop Mar 22, 2020
    Caomhin , via OnePlus 6T , Mar 22, 2020 :
    Give it as feedback and/or as a Bug. Sounds like Bluetooth working fine with the exception of the LG glitch. Doubt there is much can be done there, unless LG have a firmware update for the soundbar to make it Android 10 compatible.
    Report a Bug
    Feedback tool
  10. atomicbetty964
    Cupcake Apr 23, 2020
    atomicbetty964 , Apr 23, 2020 :
    Hi not sure if you are still having this problem, but what worked for me was adding a new apn with hs.vodafone.ie. put everything else as default. The phone then overrode the original undeletable apn. This then allows you to delete the new apn you created. My hotspot then started to work. Hope this helps
  11. G_Karothikeyan
    Ice Cream Sandwich Apr 24, 2020
    G_Karothikeyan , Apr 24, 2020 :
    There is no issues go ahead
    dm00389731 likes this.
  12. ronaksworld
    Jelly Bean Apr 24, 2020
    ronaksworld , Apr 24, 2020 :
    Do not update using OTA, manually download the full OTA 1.9GB approx and then update it.
    Caomhin likes this.
  13. X1561876089137
    Cupcake May 13, 2020
  14. Caomhin
    Lollipop May 13, 2020
    Caomhin , via OnePlus 6T , May 13, 2020 :
    Check 1st post in 10.3.3 thread, this is an old redundant thread.
    Artemus. likes this.
  15. adi1001
    Honeycomb May 13, 2020
  16. adi1001
  17. Caomhin
    This the 10.3.1 thread. It's is now a redundant thread.
    Check 10.3.3 release thread for info how to get 10.3.3 manually, many posts there with suggestions on how to do this.
  18. X1561876089137
    Cupcake May 14, 2020
    vikkvikk likes this.
  19. Swejuggalo
    KitKat May 14, 2020
  20. PerfectStorm
    Donut May 14, 2020
    PerfectStorm , May 14, 2020 :
    I had same problem right after upgrade to android 10.. the only solution was to load other Gcam versions..
