282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. vikkvikk
    Eclair May 14, 2020
    vikkvikk , May 14, 2020 :
    switch off video enhancer.. in display settings. it helps in battery drain.
  2. X1561876089137
    Donut May 14, 2020
    X1561876089137 , May 14, 2020 :
    off hi h video enhancer
  3. adi1001
    Honeycomb May 14, 2020
  4. Caomhin
    Marshmallow May 14, 2020
    Caomhin , via OnePlus 6T , May 14, 2020 :
    Depends, if you are in a hot climate or not.
    If you are in a hot climate such as 30° or higher, The air temperature at your location can cause the phone to heat while in use or charging. 6 series phones have no active cooling.
    Artemus. and adi1001 like this.
  5. adi1001
    adi1001 , via OnePlus 6T , May 14, 2020 :
    it is happening (heating) since(yesterday) i updated to 10.3.3.
    Caomhin likes this.
  6. Caomhin
    As I said climate can play a part. If you have a screenshot prior to installing 10.3.3 it would be good to compare.
    Also it can take a couple of charge cycles for an update to settle, as Android will be optimizing the phone.
    adi1001 and Artemus. like this.
  7. Swejuggalo
    Lollipop May 14, 2020
    Swejuggalo , via OnePlus 7 Pro , May 14, 2020 :
    You may want to check battery stats too. You may have an app that acts crazy... Had a other user the other day with a huge percentage of battery draining by Snapchat. That was using the CPU heavily and causing a lot of heat. Only screen surpassed it's battery usage.
    The ambiant temperature can always be nice to know when discussing heat issues. But here it sounds more like some kind of workload is draining and causing extra heat.
    adi1001, Artemus. and Caomhin like this.
  8. adi1001
    Honeycomb May 15, 2020
    Caomhin likes this.
  9. adi1001
    adi1001 , via OnePlus 6T , May 15, 2020 :
    i did a factory reset on next day after update.
    even while resetting it was heating.
    i wiped totally.
    no restoration of any backup except whatsapp chats.
  10. adi1001
    sorry buddy but bt i don't have 10.3.2 thermal stats..
    but i m sure that the heating level was not even closer to current.
    it was used to heat while gaming like PUBG and call of duty.
    Now in normal usage like i am now typing this msg even then also it is currently heating top portion of device (i.e. onwards oneplus logo till top secondary mic and metal frame which is holding volume key and alert slider and all things) like heater.
  11. adi1001
    now while jst typing this msgs device eaten 3% battery out if 100.
    i jst did 1st charge cycle which is charged to 100% overnight keeping on.
    Kleb32 likes this.
  12. adi1001
  13. adi1001
    apps are showing that they are normal.
  14. Caomhin
    Marshmallow May 15, 2020
    Caomhin , via OnePlus 6T , May 15, 2020 :
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Go through 3 to 4 charge cycles, leave on charge beyond full capacity for a couple of hours. Preferably overnight.
    Charging, battery, performance, caches and battery calibration myths busted
    https://forums.oneplus.com/threads/...-and-battery-calibration-myths-busted.993896/
    If its still not improving, backup your phone, full factory reset, Delete All Data, as in wipe your phone completely, and repeat the steps above.
    After Backing up the phone.
    Go to Settings,
    System,
    Reset Options,
    adi1001 and Swejuggalo like this.
  15. adi1001
    i did it brother.
    today morning i completed one charge cycle by keeping on charging overnight with ON state.
    Caomhin likes this.
  16. adi1001
    can u tell me what should be the cpu temperature normally ?
  17. Caomhin
    adi1001
    At idle, this is what mine is showing in CPU-Z
    It will generally run at between 30° and 40° approx
  18. adi1001
    Honeycomb May 16, 2020
    adi1001 , via OnePlus 6T , May 16, 2020 :
    mine is always 38 (mostly 45) to 60 since i updated to 10.3.3[e]1f613[/e][e]1f625[/e][e]1f622[/e][e]1f630[/e]🥵
    i m not understanding that what should i do....
    it wasn't behaving like this before when i was on 10.3.2.
  19. Artemus.
    Nougat May 16, 2020
    Artemus. , May 16, 2020 :
    What's the ambient temp in your area right now?
    Caomhin likes this.
  20. adi1001
    how to find that now?....i don't have any thermometer....i have jst oneplus whether forcast app.
