282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. adi1001
    Honeycomb May 16, 2020
  2. Artemus
    Moderator, Community Hero 2020 Moderator May 16, 2020
    Artemus , May 16, 2020 :
    Okay, yep. That's the reason your temps are high. Hot-as-hell ambient temps = hot-as-hell phone. No updates will fix this, this is typical of all devices without an internal cooling method.
    Caoimhín likes this.
  3. adi1001
    adi1001 , via OnePlus 6T , May 16, 2020 :
    it mean until and unless temperature does not go down it will heat ?
  4. Artemus
    Yes. Think of it this way: does food ever cool when it's inside of an oven?
    Caoimhín and adi1001 like this.
  5. adi1001
    kk i got it..
    thank u for attention.
  6. adi1001
    but it wasn't like this when i was on 10.3.2 ....
    it is started jst after updated to 10.3.3.
    what u think ?
  7. Artemus
    It's always been like that, you just haven't noticed till now. Or maybe it's gotten hotter in your area since February?
  8. adi1001
    brother i jst updated 3 days ago........ before that ut wasn't like that.
    it was use to get heated for 5 10 mins only after charging the device when i was on 10.3.2.
  9. Artemus
    You didn't answer my question though.
  10. adi1001
    yes it a bit hotter from april.
    bt device heating wasn't there before 10.3.3.
  11. Artemus
    Well, blame your hot country.
    adi1001 and Caoimhín like this.
  12. Caomhin
    9 Series Expert, Participator of the Year Community Expert May 16, 2020
    Caomhin , via OnePlus 6T , May 16, 2020 :
    Have you tried the steps I mentioned, also check if the following an help. Some say it does, but others say it doesn't, so it would be something you might have to check.
    Also ensure you optimise the apps and phone the way I mentioned previously.
    Wipe cache partition
    Turn off your device.
    Press and hold the Volume down and Power button at the same time.
    When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    Tap English.
    Tap Wipe data and cache.
    Tap Wipe cache.
    Tap Yes to continue.
    Tap Reboot to restart the phone.
    Artemus likes this.
  13. adi1001
  14. adi1001
    yes i did that 1 day ago.
    now my 2nd charge cycle is going on... today i m doing full tym gaming
  15. Maniviper
    Donut May 19, 2020
    Maniviper , May 19, 2020 :
    hai I can update 10.3.3 version last week that tym to till now charge the phone within 10min phone can heated. how can reduced the heat??plz tell and why phone can heat??
  16. rHITkM.
    Jelly Bean May 19, 2020
    rHITkM. , via OnePlus 6 , May 19, 2020 :
    QUOTE="Maniviper, post: 21618893, member:2378537"]hai I can update 10.3.3 version last week that tym to till now charge the phone within 10min phone can heated. how can reduced the heat??plz tell and why phone can heat??
    For your information phone gets heat up up during charge an
    d temperature can range from 35°c to 45°c.
    the SURFACE you put your phone during charging and ambient temperature decides the heat dissipation. if you put your phone on bed mattress or sofa or pillows, and
    any thing that does not conduct heat and not flat then your phone will get heat up .
    Try to put phone on desk table.
    Pravi1205 and Artemus like this.
  17. C1564682580579
    Cupcake May 20, 2020
  18. Artemus
    Moderator, Community Hero 2020 Moderator May 20, 2020
    Artemus , May 20, 2020 :
    It's... already out, depending on your country.
  19. Pravi1205 , via OnePlus 6 Midnight Black , May 22, 2020 :
    I am so facing same issue with after update.
  20. Caomhin
    9 Series Expert, Participator of the Year Community Expert May 22, 2020
    rHITkM and Artemus like this.
