282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. Caomhin
    Lollipop Jan 26, 2020
  2. Alex Sem
    Gingerbread Jan 26, 2020
    Alex Sem , Jan 26, 2020 :
    battery on 10.3.1. on my 6t device. In addition to the period of my sleep, I practically did not let the smartphone out of my hands.
  3. Ajit Sheoran
    Cupcake Jan 26, 2020
    amirsheikh15 likes this.
  4. S1560780573434
    S1560780573434 , Jan 26, 2020 :
    now i m facing wifi connection problem as well. what the hell is going on after lastest Android 10 update..apps asking me for my location permission often.old and new apps as well.plzz help me i don't like this update..i wana roll back to recent update version.
  5. souravka6
  6. AnonymousWP
    The Lab - OnePlus 7 Pro Reviewer Jan 26, 2020
    AnonymousWP , Jan 26, 2020 :
    OnePlus is still not rolling out the update for the OnePlus 6. I guess they pulled it again due to bugs, or because it's Chinese New year. Though that'd be strange, because you just don't announce an update but then not rolling it out. That's giving false hope.
  7. Girish4444
    Eclair Jan 26, 2020
  8. adityarajsaha
    Froyo Jan 26, 2020
  9. G_Meng_Xu_niXY
    Eclair Jan 26, 2020
    jitu@111 likes this.
  10. jitu@111 likes this.
  11. Caomhin
    Caomhin , via OnePlus 6T , Jan 26, 2020 :
    As stated its a Staged Random rollout, 6T has it, am sure OP are using it to test to ensure its working OK, it will be out for 6 as soon as OP decide to push it there. Have a little more patience.
  12. Caomhin
    This will not work for USA TMobile phones. International Global only.
    Install latest OOS 10.3.1 incremental & now full update released for 6T, 6 should be showing soon, it is a Staged Rollout, so if you don't see it via OTA, you may need to do it via 3rd party app Oxygen Updater from the Playstore, see if it fixes any issues you may have.
    In Oxygen Updater settings, you can set the update method to incremental if you are already on 10.3.0, if you are on any earlier version to this, set update method to full update.
  13. bramgoodwin
    bramgoodwin , via OnePlus 6 , Jan 26, 2020 :
    Major issue in reading forums is region of user is not identified, so don't know if it is relevant. OP needs to have sort by location.
  14. S1580041264871
  15. Caomhin
    The only region where the software is different is the USA, as the deal with TMobile means the phones have slightly different software to suit TMobile and currently it's only 6 & 7 series phones as far as I know.
    Have heard Verizon will be offering the OP 8 series, which means they may have their own bloatware included to suit their customers,so again the USA software versions will be different.
  16. Caomhin
    [e]2b06[/e]️🙄 3 posts above yours 🙄[e]2b06[/e]️
    ironass likes this.
  17. andythw
    Eclair Jan 26, 2020
    andythw , via OnePlus 6 , Jan 26, 2020 :
    I am prepared to wait for the update. in the past any big issue have been fixed quickly with another update. Any battery issue settles down after a few full charges. so a little wait is fine by me especially if it's to double check for bugs.
    Swati_Kaushal12 likes this.
  18. Q1577023076423
    Q1577023076423 , Jan 26, 2020 :
    You still didn't fix the Facebook video playback issue, the random system lag and the battery life being worse than Android 9
