282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. ShaunTheBeast
    Cupcake Jan 29, 2020
  2. Ihor_Syrota
    Froyo Jan 29, 2020
    Ihor_Syrota , Jan 29, 2020 :
    You know this is not a big problem to wait till next update, even month or half-year :) The issue is that OP guys making (not the first time) update announcement and after that, they send to a few clients update and after that, you must wait a loooooonnggg time :)
    I think if it's not for the first time and they must hire some professional QA team that will test before such announcement and only after that send updates )) Not making us waiting, waiting, waiting. BTW: I already have Google Pixel and I think to sell OP6 + buy some Google device. And this is not all thing that I'm waiting from OP guys, ex.: camera focus issue, low signal quality, display brightness (my eyes), display frequency (my eyes), etc...
  3. KoKo..!
    Gingerbread Jan 29, 2020
  4. ShaunTheBeast
  5. Frank1016
    Donut Jan 29, 2020
  6. anilvlyid
  7. dev8085
    dev8085 , Jan 29, 2020 :
    i did not have 10.3.1 version..still its on 10.3.0 ..
    and system is not showing any update
  8. Jamze
    Ice Cream Sandwich Jan 29, 2020
    Jamze , Jan 29, 2020 :
    Bit more detail so people can help? WiFi is working well for me on 10.3.0. What version are you on and what sort of WiFi networks?
    Caoimhín and ironass like this.
  9. Frank1016
    Donut Jan 29, 2020
    Frank1016 , via OnePlus 6T , Jan 29, 2020 :
    I have 10.3.1
    The 5ghz doesn't work like in the first release of android q.
  10. Jamze
    Couple of ideas:
    - Sure the 5Gz signal strength is strong enough? 10 might be moving to 2.4GHz as it thinks that is better quality.
    - Do you have WEP enabled on the 5Gz? Some reports that Android 10 struggles with WPA2 so might fall back.
    Is this at home or work? Single AP or multi/mesh? I had to turn off the fast transition protocols (802.11k/r etc.) on mine to get my older devices working reliably.
    Caoimhín likes this.
  11. tanish_kapadia
    tanish_kapadia , Jan 29, 2020 :
    after update, phone is start heating so much when continue using it before update there is no heating issue & battery draining so fast before update i charge 1 time its work 1&half days bt now only 1 day, this is not good at all. after update i see this both issue. hope you solve it soon.
  12. sivaraman.sony@g
    Eclair Jan 29, 2020
  13. Boubaker01
    Boubaker01 , Jan 29, 2020 :
    guys,we didn't get the update yet(Op 6 users) because one plus is making sure that this update has to be released without any possible issues,so there is no need to be worried like that, and for the op 6t users that they have some issues in this update, it will be fixed as soon as the update rolls out for op 6 users.
    I don't know that if they will release another update for op 6t users but all i know is that this update will be more stable and better than previous versions
  14. Caomhin
    OnePlus 9 Series Expert Community Expert Jan 29, 2020
    Caomhin , via OnePlus 6T , Jan 29, 2020 :
    Just in case there is an App hogging resources, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    Battery Calibration/Heating Tips: How To Improve Battery Life !!
    https://forums.oneplus.com/threads/...ting-tips-how-to-improve-battery-life.556988/
  15. Jamze
    My money is on 10.3.2 appearing in a few weeks.
    kaihp, Boubaker01 and Caoimhín like this.
  16. E1538682188679
    E1538682188679 , Jan 29, 2020 :
    I have question to users new oxygen, when I try to write something in box on yt or messenger or other apps can't see letters really often and this happend after new oxygen installation. Firefox it's freezing sometimes... Only way to do something is get out and in again. Just me or other problem also ?
    edit: oh now I can see I have 10.3.0 but no new one yet :/ 6t
  17. Alex Sem
    Alex Sem , Jan 29, 2020 :
    [QUOTE = "Jamze, post: 21297062, member: 552573"] Мои деньги на 10.3.2 появляются через несколько недель. [/ QUOTE]
    Maybe then 10.4.0 ??). After all, 10.3.1 is essentially a quick fix for errors outside of any plan. According to the schedule, the update was supposed to be somewhere in February.
    Jamze and Caoimhín like this.
  18. Dhayanand82
    Eclair Jan 29, 2020
    Dhayanand82 , Jan 29, 2020 :
    Same here. no updates yet
  19. M1535275091407
  20. Deactivated User
    Jan 29, 2020
    Caoimhín and Jamze like this.
