282
OxygenOS 10.3.1 for the OnePlus 6 and 6T
  1. muhammadkhaleeq
    Donut Jan 29, 2020
  2. FaheemSiddiqui
    Eclair Jan 29, 2020
    Caomhin likes this.
  3. FaheemSiddiqui
    Eclair Jan 29, 2020
    Caomhin likes this.
  4. E1527248706802
    Cupcake Jan 29, 2020
  5. p51d007
    KitKat Jan 29, 2020
    p51d007 , Jan 29, 2020 :
    I wish I had a dollar for every "I haven't received/when will I receive" the update.
    I could buy an island somewhere & retire.
    Good lord people! The update is staged on purpose. If they blasted it to every flipping phone at the
    same time, for one, it would swamp their server. Also, if there was a bug that got out, it would screw all
    the phones at the same time.
    In this case, he who is last, is better served. :rolleyes:
  6. Lelander2015
    Gingerbread Jan 29, 2020
    Lelander2015 , via OnePlus 6 , Jan 29, 2020 :
    6t is old too. irrelevant. we chose OnePlus for software support and pricing.
  7. Artemus.
    Nougat Jan 29, 2020
    Artemus. , Jan 29, 2020 :
    Updates won't fix your slowness problems. You have to format your phone to solve that.
    drl431 likes this.
  8. Caomhin
    Marshmallow Jan 29, 2020
    Caomhin , via OnePlus 6T , Jan 29, 2020 :
    Check this thread for info about update requests.
    https://forums.oneplus.com/threads/software-update-excitement-thread.993639/
    Also check the Note about Staged Random Rollout to limited users in the first post at the top of the thread.
    Artemus. likes this.
  9. Caomhin
    This will not work for USA TMobile carrier phones. International Global only.
    You can install latest OOS 10.3.1 incremental & now full update released for OP6T only currently
    OP6 should be showing soon.
    it is a Staged Rollout, so if you don't see it via OTA, you may need to do it via 3rd party app Oxygen Updater from the Playstore.
    In Oxygen Updater settings, you can set the update method to incremental if you are already on 10.3.0, if you are on any earlier version to this, set update method to full update.
    drl431 likes this.
  10. Sainil
    Donut Jan 29, 2020
    Sainil , Jan 29, 2020 :
    I have a problem with my Alert Slider. the Silent one doesn't work. i slide from Ring to Vibrate it works..but when i go to silent it still shows as Vibrate only.
    can anyone please reply to this comment. need help so bad.
    suraj1595 likes this.
  11. Caomhin
    If you mean the physical slider, the usual way to fix it, is to get a fine dry toothbrush and clean the slider. Usually works most of the time.
  12. 2pints
    Ice Cream Sandwich Jan 29, 2020
    2pints , Jan 29, 2020 :
    If you are waiting for an OTA update, then wait, with past updates its taken upto 10 days for the roll out to complete, tnat means you should have it by the 4th/5th of February if its not arived by then + 2 days for good measure odds on there is a bug somewhere and the roll out has been paused/halted
    drl431 and Caomhin like this.
  13. R5Copa
    Eclair Jan 29, 2020
  14. 2pints
    What version are you on at the moment, if its 9.0.x then you have a functioning device, if its 10.x.x with all its bugs its understandable, as of yet, no OP6's have had this update
  15. Florian.T
    Donut Jan 29, 2020
  16. Caomhin
  17. Peekay4u
    Eclair Jan 29, 2020
  18. Lord Titi
    Eclair Jan 30, 2020
    Lord Titi , Jan 30, 2020 :
    Just got the update by regular OTA, I just saw all the messages up there, but in your opinion, are there battery drain problems again in this version, or any lag issue ?
    I'm still on Android 9, don't want to break my phone when it is working fine with OP's murdering updates such as 10.1 and 2
    Naveen_006 likes this.
  19. Caomhin
    Marshmallow Jan 30, 2020
    Caomhin , via OnePlus 6T , Jan 30, 2020 :
    On 10.3.1 since day one, runs a smooth as butter, however I did do a full factory reset on 10.3.0 beforehand so that may have had an effect.
  20. freeshared
    Froyo Jan 30, 2020
    freeshared , Jan 30, 2020 :
    6 or 6t?
    Which country/vpn
    As far as I followed this thread,10.3.1 solves most problems introduced in earlier android 10 versions.
    If you are on android 9 and jumping directly to 10 you will need to do factory reset
    Lord Titi likes this.
