62
OxygenOS 10.3.10 for the OnePlus 6 and 6T
  1. iamrj
    Ice Cream Sandwich May 4, 2021
    iamrj , via OnePlus 6 , May 4, 2021 :
    After 2020, there are many lags and bugs that oneplus inbuilt apps, ear buds etc since they couldn't solve and on threads there is no point as they don't reply nor their feedback gives any solution if you lucky you will recieve an update if not then there is no solution also on playstore just type oneplus ltd many are millions user gave negative views because bugs and lags developers fail to do the needful also after three years A11 is expected on august but it's not confirmed.
  2. GaneshKunte
    Honeycomb May 4, 2021
    GaneshKunte , May 4, 2021 :
    Do u encounter the frame drop in UI ???
    Major concern for me. I use mobile a lot, I usually face frame drop atleast twice or thrice in a day.
    Confirm me have u encountered this issue? Because during last update I had raised feedback to OnePlus. Just wanted to know has it taken seriously or not 😂
    D.Sai Suhail Baba and iamrj like this.
  3. Shanpeshwe
    Gingerbread May 4, 2021
    Shanpeshwe , via OnePlus 6 , May 4, 2021 :
    I also experienced that in last update..
    I reseted my phone and launcher version latest installed from apkmirror. After this not issued till now. Launcher version is 5.1.3.
  4. Vikashlb
    Vikashlb , via OnePlus 6T , May 4, 2021 :
    OnePlus bullets z bass edition?
  5. chiraggorwadkar
    Cupcake May 4, 2021
  6. Vikashlb
    that doesn't work its not even optimized for 6/6t
    buy Bullets z it doesn't have any problem
    (i also bought bass edition first and replaced it 3 times and still had the issue so finally bought bullets z Normal edition and which btw works fine).
    chiraggorwadkar likes this.
  7. GaneshKunte
    While doing reset have u selected the Erase Internal storage or not??
    Because I had done reset my phones 2 times so far. Still I was facing so asked fixed or not.
  8. Shanpeshwe
    Yes complete wipe all data and then reseted.
    It worked for me but dnt know will it work for u or not.
  9. chiraggorwadkar
    Cupcake May 4, 2021
    chiraggorwadkar , via OnePlus 6 , May 4, 2021 :
    Thanx for suggestion 👍🏻🤘🏻
    I will buy that another version
  10. iamrj
    Royal_RJ and D.Sai Suhail Baba like this.
  11. Anand Kajale likes this.
  12. Z1612296366828
    Cupcake May 4, 2021
    ShanuAnirudh likes this.
  13. Z1612296366828
    Cupcake May 4, 2021
    iamrj likes this.
  14. amanps
  15. Auristic
    Lollipop May 4, 2021
    Royal_RJ, rhyd1am, dashxdot and 3 others like this.
  16. Auristic
  17. amanps
    amanps , via OnePlus 6 , May 4, 2021 :
    oneplus 6 series update will be discuss in oneplus 6 series forum only. shaktiman
  18. Anand Kajale
    Donut May 4, 2021
    Anand Kajale , via OnePlus 6 , May 4, 2021 :
    We want more customisation...
    Battery drain issue to be fixed like Android 8.0
    No option to select more payment options on finger print but only Paytm
    Sad User experience :(
  19. Anand Kajale
    Donut May 4, 2021
    Camera picture quality is crab after previous updated
    There is lot of difference between old pictures nad new captured
    Major fix needed
    Camera
    Battery drain
    Screen Flickering
  20. iamrj
    Hi. I feel rather downloading custom roms it's better to stick with android 10 because the Ul and other features are very simple comparing lineage OS 18.1 (Android 11) Android 10 is better this is my personal opinion so don't think it's worth downloading. Thanks for sharing this information it had cleared my all doubts. Applause.
