62
OxygenOS 10.3.10 for the OnePlus 6 and 6T
  1. MasterManish
    Eclair May 11, 2021
    Ronesso17 likes this.
  2. Tom886
    Gingerbread May 11, 2021
    Tom886 , May 11, 2021 :
    Replace "random" with "qualified". :p
    Qualified means in that case, users who are not complaining and/or whining, because they actually know how to report bugs (if any) and using the appropriate channels to report these.
    All others are not "qualified" enough to provide a valuable feedback, especially the ones who are whining.
    21 days for valuable feedback if there bugs, if nothing serious, the download is available for all.
    Cheers
  3. VikramMohal
    Ice Cream Sandwich May 11, 2021
    Royal_RJ and rHITkM. like this.
  4. D.Sai Suhail Baba
    Jelly Bean May 11, 2021
    Royal_RJ likes this.
  5. VikramMohal
  6. Master_TC
    KitKat May 11, 2021
    D.Sai Suhail Baba likes this.
  7. VikramMohal
  8. VikramMohal
  9. Master_TC
    KitKat May 11, 2021
    D.Sai Suhail Baba and mohal like this.
  10. VikramMohal
    Royal_RJ and D.Sai Suhail Baba like this.
  11. Bobbie63
    Marshmallow May 11, 2021
    Bobbie63 , May 11, 2021 :
    I'm afraid the screen shots are needed, if only if it were for the time stamps. These logs are very large and they can't go through all lines.
  12. Royal_RJ
  13. Royal_RJ
  14. scicciarella
    Eclair May 11, 2021
    scicciarella , via OnePlus 6 , May 11, 2021 :
    The last time I tried to upgrade to OS 10, I saw huge battery drain at idle and screen quality decreased. Any feedback on these issues (if you've experienced them) with 10.3.10? Also, still running 9.0.9 and reluctant to upgrade.
  15. K1577555224305
    Honeycomb May 11, 2021
  16. K1577555224305
    K1577555224305 , May 11, 2021 :
    Tbh I didn't feel any great changes but had to do for getting updates.
    9.0.9 worked fine for me.
    Battery drain is issue is not straight forward. Just after update it drains too much but after a month it gives more screen on time. Idk 🤷 mine stated to heat recently and I am on 3.9 not 3.10
    scicciarella likes this.
  17. Master_TC
    KitKat May 11, 2021
    Master_TC , May 11, 2021 :
    On my 6t all works fine. I don't play, so I have no heating or battery drain.
    After update make a factory reset. That is important. So you get a fresh install of A10. In the first days/weeks you have a high battery drain. But this is normal, because Android has to optimize all apps and the battery can settle down.
  18. scicciarella
    Eclair May 11, 2021
    Appreciate your help. I'm trying to avoid a factory reset but will definitely consider it
  19. Master_TC
    KitKat May 11, 2021
    You can also try upgrading without a factory reset, but you may get errors that no one can explain to you
    Caoimhín and scicciarella like this.
  20. SxCshiplu
    Cupcake May 11, 2021
