62
OxygenOS 10.3.10 for the OnePlus 6 and 6T
  1. Archit@123
    Honeycomb May 12, 2021
  2. B_Wrath
    Nougat May 12, 2021
    B_Wrath , May 12, 2021 :
    1. Monthly FAQ thread.
    2. Update announcement threads.
    3. If you have a proper backup and data to support your claims, a new thread which encompasses all the issues from all the builds which are not solved yet.
  3. Archit@123
    Archit@123 , via OnePlus 6T , May 12, 2021 :
    I raised Random frame drop issue when OOS10 open beta 1 was launched no one listen and ever replied.
    I raised the complain again in 10.3.9 update through community feedback app and they asked for logs. But I asked them that this issue occur randomly and no specific way to reproduce.
    I have used live chat feature and they told me they have reported the issue to dev and wait for next ota but here it is 10.3.10 still not fixed.
    I am not the only one who has reported this issue check the previous thread so many users have complaint this issue.
  4. B_Wrath
    Nougat May 12, 2021
    Then ping them again or tag the relevant staff.
  5. Archit@123
    I will raise the complain and tag them again if they won't reply or take necessary action I will create a thread
    D.Sai Suhail Baba and B_Wrath like this.
  6. Vikashlb
    Vikashlb , via OnePlus 6T , May 12, 2021 :
    Devs are busy working on their latest devices so called "flagships".
    So i dont think they will fix bugs in older devices anytime soon or they wont consider it fixing.
    D.Sai Suhail Baba and Archit@123 like this.
  7. Darshan5015
    Froyo May 12, 2021
  8. Kaushik2408
    Eclair May 12, 2021
    Kaushik2408 , May 12, 2021 :
    From next time I'll never ever recommend OnePlus to anyone.Oneplus set an example how to destroy a big fanbase by putting so called others UI features with oxygen OS. oxygenOS is the only thing I guess people like to used but now it's done .Welcome to Oppo, Xiaomi,Vivo party Guys.
  9. Auristic
    Lollipop May 12, 2021
    Auristic , via OnePlus Community App , May 12, 2021 :
    1- Wait
    2- Use Oxygen Updater to get it immediately
    3- No more option
    Next time please read before posting as this has been said multiple times here!
  10. PVSKVR
    Cupcake May 12, 2021
  11. rhyd1am
    KitKat May 12, 2021
    rhyd1am , May 12, 2021 :
    It's a staged, random rollout. It goes first to a smaller group of "random" users, before going out to increasingly larger groups of users, and can take a couple of weeks to reach everyone.
    It's done this way to try to minimise the chance of any major bugs getting out there. Be patient and it'll soon reach your device 🙂
    Refer to the post just before you're own for your options
  12. ARHS2710
    Donut May 12, 2021
    ARHS2710 , May 12, 2021 :
    Did this imei null issue happened after u installed custom ROM or after u tried to revert to Oxygen OS via Msm tool.
    imei null issue usually happens when u revert to stock ROM via Msm tool and have selected SMT DOWNLOAD option instead of upgrade option in MSM tool window.
    Never select first option SMT DOWNLOAD in MSM, otherwise your imei will be gone.
  13. J1583957566832
    J1583957566832 , via OnePlus 7T , May 12, 2021 :
    Now what is the solution to get back imei number
  14. DragonButt
    Eclair May 12, 2021
    DragonButt , via OnePlus 6 , May 12, 2021 :
    Why do you guys keep backing them, are you fine with the performance of your OnePlus 6/6t?
    My 1+6 struggles to run COD in background for a min while i open a notification of an other app..
    kn_raghavendra likes this.
  15. ARHS2710
    Donut May 12, 2021
    Depends. How did this imei null issue occured?
    If you will visit OnePlus service centre, they will simply tell you to change the mainboard
  16. J1583957566832
    I doomed completely there's is no other way to fixed this
  17. ARHS2710
    Donut May 12, 2021
    imei no. are stored in EFS partition, I believe.
    Always take a backup of EFS partition.
    To answer your question, yes you can recover your imei no
  18. J1583957566832
    How can I recover my imei number and why my phone is restarting and wifi Bluetooth nothing is working
  19. K1577555224305
    K1577555224305 , May 12, 2021 :
    Although I didn't try updating but I went a step ahead and disabled it.. I learnt webview is actually web+view and the apps which use html5 .. and probably that's what gives system/os level based ads ..
    Idk just my experiment and observations .
    All most all bite sized apps work on webview.
  20. ARHS2710
    Donut May 12, 2021
