62
OxygenOS 10.3.10 for the OnePlus 6 and 6T
  1. ItsRavi25
    Jelly Bean May 15, 2021
    ItsRavi25 , via OnePlus 6T , May 15, 2021 :
    Did you read what is written in 1st post ?
    I just provide the different ways for the Faster update.
    I personally updated my device using OXYGEN UPDATER, everything working fine.😇
    ironass, Caoimhín, Auristic and 2 others like this.
  2. yusuf...parekh , via OnePlus 6 Silk White , May 15, 2021 :
    Yeah but
    dihaj likes this.
  3. rhyd1am
    KitKat May 15, 2021
    rhyd1am , May 15, 2021 :
    Personally I don't tend to use Oxygen Updater these days. I prefer to download the file myself and install it. However, there is zero difference between using oxygen updater and waiting for the OTA. The file you receive via oxygen updater, is the exact same file you'll get through OTA.
    Oneplus' ONLY reason not to recommend oxygen updater, is because it is not made by OnePlus. Any difference you've seen between the 2 methods of updating are purely down to your perception, not down to any actual difference 🤷‍♂️
  4. Auristic
    Lollipop May 15, 2021
    Auristic , via OnePlus Community App , May 15, 2021 :
    Why is that?
    If you want OnePlus to push the update to you then your ONLY solution is to WAIT SILENTLY!
  5. Auristic
    There is NO DIFFERENCE since it's the SAME FILE so either use Oxygen Updater or don't, that's your personal choice, but please don't spread misinformation as you obviously don't have a clue about how this app works!
  6. Subbu186
    Cupcake May 15, 2021
  7. yusuf...parekh , via OnePlus 6 Silk White , May 15, 2021 :
    I know bcoz i download 9.0.7 and 10.3.4 via O2 updater app and i found the difference after using it
  8. yusuf...parekh , via OnePlus 6 Silk White , May 15, 2021 :
    Plzz wait for another week or so (hate to say this ) but i am too waited for this.......
  9. Auristic
  10. FrostyFox
    Froyo May 15, 2021
    FrostyFox , via OnePlus 6 , May 15, 2021 :
    You know nothing about the app cause thousands of people use oxygen updater flawlessly, try reading though reddit forums too, oxygen updater has no issues whatsoever, it provides the same incremental file as its on oneplus ota. My op6 has been updated through the same updater everytime with no issues at all. Please refrain from spreading false information.
  11. K1577555224305 likes this.
  12. rhyd1am
    KitKat May 15, 2021
    Well of course they're going to say that to you, because it's not an app they have made.
    Also I suspect they do not want people to use the app because it bypasses oneplus' preferred way to roll out updates in a staged manner.
    Nobody is trying to force you to use it, but spreading false information is not necessary.
    drl431, ironass, ItsRavi25 and 4 others like this.
  13. yusuf...parekh , via OnePlus 6 Silk White , May 15, 2021 :
    What happen if i download 10.3.10 from O2 updater and the few month will i get automatically another new update by oneplus or only do via O2 updator
    Finally i am using it that why and anybody sure there will be no bugs via O2 UPDATOR
  14. rhyd1am
    KitKat May 15, 2021
    1. You will continue to receive future OTA updates as usual after updating via Oxygen Updater.
    2. Any bugs that any user experiences, have nothing to do with the Oxygen Updater app. The file that the app uses is THE EXACT SAME FILE that OnePlus pushes with the OTA 🤷‍♂️
    drl431, ItsRavi25, Auristic and 2 others like this.
  15. yusuf...parekh , via OnePlus 6 Silk White , May 15, 2021 :
    Ok if after i do factory reset ,it will downgrade 10.3.9 or would be same
  16. Akshay1805
    Donut May 15, 2021
    Akshay1805 , via OnePlus 6 , May 15, 2021 :
    Not on my Oneplus 6 as well.
    Maybe need to wait.
  17. Venkat1991
    Froyo May 15, 2021
    Venkat1991 , May 15, 2021 :
    The best build till date after long time. Smooth and no scroll issues. Battery backup looks good.
  18. rhyd1am
    KitKat May 15, 2021
    It is impossible to downgrade your device by just performing a factory reset. If you're on 10.3.10 when you reset your device, you'll be on 10.3.10 afterwards (whatever build you're on will be the same after a reset).
    To downgrade your device you need to download the correct download package for your device.
    drl431, ironass, Caoimhín and 2 others like this.
  19. R_Soumya15
    Eclair May 15, 2021
