60
OxygenOS 10.3.11 for the OnePlus 6 and 6T
  1. kouzelnik3
    Ice Cream Sandwich Jun 20, 2021
    kouzelnik3 , Jun 20, 2021 :
    When it is ready. Learn to search...
  2. K1557328612622
    Eclair Jun 20, 2021
  3. Auristic
    Lollipop Jun 20, 2021
  4. Auristic
  5. GaneshKunte
    Honeycomb Jun 20, 2021
    GaneshKunte , Jun 20, 2021 :
  6. VikramMohal
    VikramMohal , via OnePlus 6T , Jun 20, 2021 :
    Use msmtool for downgrade to check if proximity works in previous build. Or flash full zip package again and full wipe your device. If nothing else work then it is hardware problem.
    D.Sai Suhail Baba and Royal_RJ like this.
  7. VikramMohal
  8. Vikashlb
    D.Sai Suhail Baba likes this.
  9. VikramMohal
  10. FaleshC
    KitKat Jun 20, 2021
  11. VikramMohal
    Ice Cream Sandwich Jun 21, 2021
    Royal_RJ likes this.
  12. Royal_RJ
  13. Royal_RJ
    VikramMohal likes this.
  14. Auristic
    Lollipop Jun 21, 2021
  15. R_Soumya15
    Eclair Jun 21, 2021
    R_Soumya15 , via OnePlus 6 , Jun 21, 2021 :
    Mobile network signal issue, any solution plz?
    i have used 2 jio opertor, sim1 signal fluctuate more than sim2. Also sim2 network bar shows more bar than sim1.
    K1557328612622 likes this.
  16. I1624262151515
    Cupcake Jun 21, 2021
    I1624262151515 , via OnePlus 6T , Jun 21, 2021 :
    Guys, after the update my fingerprint reader doesn't work at all. I tried to reset the fingers but when trying it says I put the finger too fast on the screen every time. Which is not the case obviously, so now I can't use this feature at all to login. Can you fix it in the next update? 6T model here.
  17. cooldeepak
    Eclair Jun 21, 2021
  18. VikramMohal
  19. Death_Knight
    Eclair Jun 21, 2021
    Ronesso17 likes this.
  20. ItsRavi25
    Jelly Bean Jun 21, 2021
    ItsRavi25 , via OnePlus 6T , Jun 21, 2021 :
    Try this,Maybe this will solve the problem.
    Remove all fingerprint lock and other security lock
    Goto settings > Search for fingerprint > click on the app name (com.qualcomm.qti.biometrics.fingerprint.service ) > Forces stop> clear the cache and storage > reboot your device > add new fingerprint > done
    Also sometimes problem occurs due screen protector.
