181
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. Artemus.
    Community Hero 2020 Mar 17, 2020
    Artemus. , Mar 17, 2020 :
    What's wrong with using third-party apps?
    ironass, drl431 and Caoimhín like this.
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 17, 2020
    Caomhin , via OnePlus 6T , Mar 17, 2020 :
    OnePlus have a load of more recent apps available, some are region specific, some phone model specific, some generic across all phones. All available on ApkMirror as well.
    Their latest dialler on ApkMirror might not function on a OP6 or OP6T.
    This is by design currently.
    Read the last Paragraph on this link for more info.
    https://www.androidpolice.com/2020/...ger-on-the-play-store-for-faster-updates/?amp
    drl431 and Artemus. like this.
  3. Amar3472
    Cupcake Mar 17, 2020
    Amar3472 , Mar 17, 2020 :
    Issues with calling.
    It keeps on calling in the backend...... Even if I cut the call.
    ppavan1 likes this.
  4. Amanrae
    Honeycomb Mar 17, 2020
  5. Caomhin
    Try reset your Mobile Network, see if that helps.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
    Artemus. likes this.
  6. Caomhin
    Try a different font in Settings Customisation to see if the other font can display different languages
  7. powerpetike
    powerpetike , Mar 17, 2020 :
    is anybody has working vowifi ? after upgrade from pie I dont have anymore, very anoying already tried clean install
    ppavan1 likes this.
  8. Amanrae
    Amanrae , via OnePlus 6 , Mar 17, 2020 :
    Tried, didn't work. Thanks.
    Caoimhín likes this.
  9. Raja1856
    ppavan1 likes this.
  10. srikanth.s
  11. viveksinhaxp
    Froyo Mar 17, 2020
    viveksinhaxp , via OnePlus 6T , Mar 17, 2020 :
    so you mean I have to download the inbuilt apps from 3rd party store?
  12. viveksinhaxp
    Froyo Mar 17, 2020
  13. Caomhin
    Yes, some don't get placed on the Playstore for some reason. Just Don't download the latest Dialler app. It screws up on OP6T and probably same on OP6.
  14. viveksinhaxp
    Froyo Mar 17, 2020
    Caomhin
    Yes, some don't get placed on the Playstore for some reason. Just Don't download the latest Dialler app. It screws up on OP6T and probably same on OP6.​
    ya the dialer app is a crap and even the new message app 5.1.31 is a crap... after installing it it says app not installed.why I am getting such pop up ..don't know
  15. balluxlent
    Froyo Mar 17, 2020
    balluxlent , via OnePlus 6 , Mar 17, 2020 :
    AFTER THE 10.3.2 UPDATE,SOMETIME I AM UNABLE TO SWIPE DOWN QUICK SETTING MENU AND NOTIFICATION BAR.I HAVE TO SCREEN OFF AND ON BY PRESSING POWER BUTTON THEN IT START WORKING NORMAL.PLEASE FIX IT ASAP.THANKS.
    ppavan1 likes this.
  16. K_deep
    Gingerbread Mar 17, 2020
    drl431, ironass and Caoimhín like this.
  17. AnimeshMiri
    Froyo Mar 17, 2020
  18. syedrhashmi
    syedrhashmi , via OnePlus 6T , Mar 17, 2020 :
    Good to see improvements, but still less smooth and stable than OOS 9
    Camera was far better (specially in Slo-Mo) in OOS 9
    Smoothness of animations was better in OOS 9
    Hide Notch display was perfect in OOS 9
    DavidMeshach likes this.
  19. R1544720190141
    mr.AnujSharma and ppavan1 like this.
  20. seahero
    Froyo Mar 17, 2020
    seahero , via OnePlus 6 , Mar 17, 2020 :
    is the nfs most wanted app 3rd party app? it's never work with Android on or oxygen is 10! you can try and see what I'm saying
