181
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 17, 2020
    Caomhin , via OnePlus 6T , Mar 17, 2020 :
    Differs from persons to person, phone setup to phone setup, phone use to phone use, different apps, personalisations,, gamers, not gamers, versions of android, different battery sizes between OP6 and OP6T.
    Too many variables to be exact.
    ironass, Ambidan87 and AnimeshMiri like this.
  2. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Mar 17, 2020
    Artemus , Mar 17, 2020 :
    Third-party means developed by someone else.
    Caoimhín and ironass like this.
  3. AnimeshMiri
    Froyo Mar 17, 2020
    AnimeshMiri , via OnePlus 6T , Mar 17, 2020 :
    but according to you its good or bad....your opinion bro??
  4. Ambidan87
    Cupcake Mar 17, 2020
  5. Naorahdut123
    Froyo Mar 17, 2020
    Naorahdut123 , Mar 17, 2020 :
    Great update overall, battery life has improved alot.
    the animations are smooth and the overall experience is solid.
    make sure you clear cache before and after the update.
  6. FakeWeeb22
    FakeWeeb22 , Mar 17, 2020 :
    my phone is getting unusually hot and the battery life is much worse (about 4.5 hours screen on only using YouTube and Instagram).
  7. zayn_ys
    Ice Cream Sandwich Mar 18, 2020
  8. bramgoodwin
    Gingerbread Mar 18, 2020
    bramgoodwin , via OnePlus 6 , Mar 18, 2020 :
    Have OP6, A10.3.2 WORKS GREAT.
  9. bramgoodwin
    No, no, no A10.
  10. K_deep
    Caoimhín likes this.
  11. Tanvir.Ahmed
    Cupcake Mar 18, 2020
  12. F1531671391553
    Donut Mar 18, 2020
    iamkrafi and ppavan1 like this.
  13. G_Parmar_Vivek_UAtZ
  14. Tee_Eee_Bee
    Tee_Eee_Bee , via OnePlus 6T , Mar 18, 2020 :
    G_Parmar_Vivek_UAtZ
    I need update on my phone
    what I do.....I need updated​
    You are on the open beta software.
    If you want 10.3.2 stable software, then you can download it from your local OnePlus support page.
    Make sure the file is in the root (base level) directory, and if needed, edit the file name using your file manager to remove the '.jar' file extension. You should then be able to update via local upgrade through the settings.
    You should be able to update your phone without data loss, but do backup everything first just in case.
    Artemus and ironass like this.
  15. RajPanchal_08
    ppavan1 and eliamarisio like this.
  16. Cervantes
    Moderator Moderator Mar 18, 2020
    Cervantes , Mar 18, 2020 :
    Hi
    the update thread is a question and comment thread
    what happens when you update the system
    settings, system, system update
    Please, Use the search engine before opening a new thread
    Thread merged
    Artemus and Caoimhín like this.
  17. Cervantes
    Hi
    Please, read the first post
    so that another user of a solution you must give more details of the problem
    Thread merged
  18. edyaldea
    Froyo Mar 18, 2020
  19. Henkan
    Froyo Mar 18, 2020
    Henkan , via OnePlus 6 , Mar 18, 2020 :
    edyaldea
    Update to A10 on 6/6t is like lottery!​
    I bet you wouldn't update your computer from Windows 7/8/8.1 to Windows 10 without formatting your hard drive.
    Make a backup of all data, upgrade to A10 and then a factory reset. I did that when I upgrade to the first A10 version in december and haven't hade any issues after the following updates, A10.0.0 -> A10.0.1 -> A10.3.0 -> A10.3.1 -> A10.3.2
  20. umerbinfarook
    umerbinfarook , Mar 18, 2020 :
    i tried to update on 2g network but after completion it shows signature verification failed
    what to do?
