157
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. Caomhin
    KitKat Mar 25, 2020
    Caomhin , via OnePlus 6T , Mar 25, 2020 :
    You will need to contact Jio and ask them why?
  2. Caomhin
    KitKat Mar 25, 2020
  3. W1569995511835
    Donut Mar 25, 2020
    W1569995511835 , via OnePlus 6T , Mar 25, 2020 :
    wifi calling update came in nokia in their last Android update which not in oneplus 6t update.
  4. G_Vasil_Bhisti_yfNb
    Cupcake Mar 25, 2020
    G_Vasil_Bhisti_yfNb , Mar 25, 2020 :
    i had a unusual problem with my one plus 6 . I updated it to10.3.2 7 to 8 days ago. but of sudden it started to restart again and again if i shutdown..it starts itself and restart...
    restarts after every 10 to 20 sec..
    i cleaned the cache in recovery mode... nothing happend
    i factory reseted... nothing happen
    infact created more problem...when device was started new..there was no network detected..not even detect the wifi..and was stuck...
    i removed my sim cards and
    i started my device in safe mode and it worked and somehow connected to wifi and able to start new...
    and now works fine.......
    DONT KNOW WHAT WAS THE REASON THIS HAPPENED AT VERY FIRST PLACE..
  5. anatolii_pleshkov
    Donut Mar 25, 2020
    anatolii_pleshkov , via OnePlus 6 , Mar 25, 2020 :
    Всем привет! На форуме пропал русский язык, в настройках есть, но не включается! кто знает как исправить, пожалуйста отпишитесь!
  6. shreyashyerawar
  7. A1585153754790
    A1585153754790 , Mar 25, 2020 :
    there is an issue in my OnePlus 6 ,after the update of oxygen os version 10.3.2, my device is reboot automatically 6 to 7 times in a day from past 4 days,this is the main issue , please help me
  8. _BlackPanther_
    Honeycomb Mar 25, 2020
    _BlackPanther_ , Mar 25, 2020 :
    I usually have zero issue with any update.
    But this time somehow app store is not updating any of my apps on wifi , on mobile data works fine.
    Tried clear cache date on Google store , framework and others but did not help.
    I know wifi is no the issue because I never had this issue.
    Any other things I need to do to fix this ?
    Thank you
  9. Z1585156867467
  10. SPlusOneC
    Donut Mar 25, 2020
    SPlusOneC , via OnePlus 6T , Mar 25, 2020 :
    Oneplus 6t on Android 10 sucks dick and I'm disappointed in OnePlus for only focusing their time to the OnePlus 7/7t and not their other devices. this will most likely be my last OnePlus device. Im still on Android 9 and it's only because I had to manually downgrade. The black bar on the bottom of the OnePlus 6t on Android 10 frustrated me so much I wanted to slap whoever with the phone that thought of about keeping it there. OnePlus is going to lose more customers coming in the future with this dumbass practices. don't ever forget the people don't forget.
    AnimeshMiri, Arn0nin0 and surendra91 like this.
  11. R1531967762163
  12. surendra91
    Gingerbread Mar 25, 2020
    surendra91 , Mar 25, 2020 :
    op 6 is first and last ...
    now mi or samsung high end
    SPlusOneC likes this.
  13. AntInPhilly
    Eclair Mar 25, 2020
  14. Kytharsis
    Nougat Mar 25, 2020
    Kytharsis , Mar 25, 2020 :
    When did you last reset the device?
    Caomhin likes this.
  15. AntInPhilly
    Eclair Mar 25, 2020
    AntInPhilly , via OnePlus 6T , Mar 25, 2020 :
    This time after I updated from 9.0.17 to 10.3.2 I completely wiped everything (including pictures) and went with a fresh install of 10.3.2, and I manually installed each app I previously had. I didn't restore anything except for WhatsApp chat history.
  16. AntInPhilly
    Eclair Mar 25, 2020
    I thought by disabling RAM Boost that did the trick but here we are 24 hours later back to the same stuttering issues again. It's only intermittent not all the time
  17. Runnerista
    Eclair Mar 25, 2020
    Runnerista , via OnePlus 6T , Mar 25, 2020 :
    Nothing you can do about that. It is just shitty coding, poor debugging and software optimization. Try to contact OnePlus via Feedback tool and hope they will fix that.
    AntInPhilly likes this.
  18. Kytharsis
    Nougat Mar 25, 2020
    There might be your problem. Do not restore ANYTHING.
    Caomhin likes this.
  19. Tee_Eee_Bee
    Tee_Eee_Bee , via OnePlus 6T , Mar 25, 2020 :
    Not sure if this would have any effect, but depending on what your current setting is, try disabling or enabling DC Dimming in the OnePlus Lab under Settings->Utilities
  20. AntInPhilly
    Eclair Mar 25, 2020
    Thanks. I'll try this and check back in 24 hours with the results.
