157
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. mohdasif2402
    Cupcake Mar 25, 2020
    mohdasif2402 , via OnePlus 7 Pro , Mar 25, 2020 :
    I was having a "blank screen" problem with my OnePlus 6 after I updated it. I went to Service Center and got it downgraded and it was fixed. Now after 3months I am facing a same issue. This is ridiculous. Please help me with the issue ASAP[e]1f64f[/e]
  2. HetSalaaa
    Eclair Mar 25, 2020
  3. Caomhin
    KitKat Mar 25, 2020
    Caomhin , via OnePlus 6T , Mar 25, 2020 :
    Your phone is one and a half years old, what do you expect. New flagship series 8 on the way. Patience is all you need.
  4. Tee_Eee_Bee
    Gingerbread Mar 25, 2020
    Tee_Eee_Bee , via OnePlus 6T , Mar 25, 2020 :
    As has been explained many times before, the space under the keyboard is due to Google's design for Android 10.
    I have the exact same space under the keyboard on my pixel 4XL.
  5. SPlusOneC
    Donut Mar 25, 2020
    SPlusOneC , via OnePlus 6T , Mar 25, 2020 :
    Tee_Eee_Bee
    I have the exact same space under the keyboard on my pixel 4XL.​
    Google and OnePlus are a bunch of idiots. why do you think Google phones dont sell and only Samsung and iPhone? because those companies listen to the ******* customers. Google is just a failed company when it comes to phones.
  6. danukadesilva
    Cupcake Mar 26, 2020
    danukadesilva , via OnePlus 6T , Mar 26, 2020 :
    does the raise to answer feature support well when pocket mode is on?
    Sometimes when i raise my phone towards my ear the phone detects that its in my pocket.
    AanandRoy likes this.
  7. Muhammad_Kashif_bahl
    Gingerbread Mar 26, 2020
  8. G1585187717348
    G1585187717348 , Mar 26, 2020 :
    Can anyone help me figure out why my one plus 6 has no network data since the update. I'm using mint mobile and they have tried everything and say it's not a problem on their end. wifi works fine. LTE connects but won't load anything
  9. Tee_Eee_Bee
    Tee_Eee_Bee , Mar 26, 2020 :
    Have you tried resetting your mobile network adapter:
    Settings->System->Reset Options->Reset WiFi, Mobile Bluetooth
    Caomhin likes this.
  10. G1585187717348
    yes I already tried that, didn't help.
  11. Tee_Eee_Bee
  12. viveksinhaxp
    Eclair Mar 26, 2020
  13. G1585187717348
    yes it was another mint card. it didn't work either. mine worked in another phone though
  14. Tee_Eee_Bee
    Tee_Eee_Bee , via OnePlus 6T , Mar 26, 2020 :
    I don't think Google have released it yet, my Pixel 4XL is also still on February Play System Update.
    Caomhin likes this.
  15. Tee_Eee_Bee
    Have you tried wiping cache in recovery mode?
    You shouldn't lose any data but it;s always a good idea to back everything up first.
    Reboot in to recovery mode via power menu or
    1. Switch off the device by holding the Power button for a few seconds
    2. After that start pressing Volume Down + Power button for a short while
    3. Release all keys when the OnePlus icon appears
    4. Then enter PIN to unlock the screen
    Select your language
    Select Wipe Data and Cache
    Select Wipe Cache
    Select Yes
    Caomhin likes this.
  16. Z1528185284566
    Z1528185284566 , Mar 26, 2020 :
    hello,
    After upgraded to latest patch updated for "one plus 6" I'm facing lot of issues
    kindly have a look into to below listed issue
    1.Screen flickering
    2.Camera is not working properly ,it gets hanged sometime ,I need to restart the phone to get the issue resolved
    3.Response time on click of the application ,it's taking lot of time .
    kindly let me know how fast this issue will be resolved, If not let me know to install the old patch release.
    Regards,
    Yogitha
  17. Cervantes
    Lollipop Moderator Mar 26, 2020
    Cervantes , Mar 26, 2020 :
    Hi
    the update thread is a question and comment thread
    Please, read the first post
    Use the search engine before opening a new thread
    Thread merged
  18. V1529036357230
    Donut Mar 26, 2020
    rushik18 likes this.
  19. Aditya Nahar
  20. Caomhin
    KitKat Mar 26, 2020
    Caomhin , via OnePlus 6T , Mar 26, 2020 :
    Suggestions to try and fix these issues have been answered hundreds of times, please check further up the thread, or use the search function above.
