157
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. Aditya Nahar
    Gingerbread Mar 26, 2020
    Aditya Nahar , Mar 26, 2020 :
    make it a SHAGUN no by answering it 101th time if u know.
  2. G1585187717348
    Cupcake Mar 26, 2020
    G1585187717348 , Mar 26, 2020 :
    yes I have also tried this, still no data function
  3. Caomhin
    KitKat Mar 26, 2020
    Caomhin , via OnePlus 6T , Mar 26, 2020 :
    Scroll up and check, spoon feeding time is over.
    ironass, drl431 and Auristic like this.
  4. Aditya Nahar
    Abe jaa be lodu....khud th tu janta nhe aaya bada bakwaas krne....
  5. X1543467636919
    X1543467636919 , Mar 26, 2020 :
    my oneplus 6T hotspot is not working when I'm trying to connect from pc using WiFi dongle...and same is working with other phone...please help
    MCunha likes this.
  6. AnimeshMiri
    Froyo Mar 26, 2020
    AnimeshMiri , via OnePlus 6T , Mar 26, 2020 :
    what the **** is going on only 7 hours to go........really oneplus is not seeking the problem of the people in the community fir battery draining issue........very poor battery life of this phone........
  7. Caomhin
    KitKat Mar 26, 2020
    You need to go through 3 to 4 full charge cycles to let the system settle after updating.
    Then check the SOT against percentage used...The time left is only an estimation, and only 3% Battery used is not an indication, wait until its down to 20% after charging it for those cycles and see where it is then.
    Auristic likes this.
  8. V1528784383877
    Eclair Mar 26, 2020
    V1528784383877 , Mar 26, 2020 :
    after this update there is lot of heating issue while on video call and other stuff please improve it or don't bring the update
  9. Caomhin
    KitKat Mar 26, 2020
    No heating in my phone, it must be just the way you have your own phone personally configured and other stuff.
    Just in case there is an App hogging resources, causing Heat issues, causing lag, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more resources than necessary.
    drl431 likes this.
  10. N1544725203334
  11. MCunha
    Froyo Mar 26, 2020
    MCunha , Mar 26, 2020 :
    Anything related to Wi-Fi is a nightmare with Oxigen A10.
  12. Ashishrazz
  13. S1537368925336
    Eclair Mar 26, 2020
    S1537368925336 , via OnePlus 6 , Mar 26, 2020 :
    While people complaining about the latest update issue, me waiting for the major update like 10.4 or 10.5, still at 10.3.0 I'm not updating cause it's not so bad to stay at this version.
  14. Caomhin
    KitKat Mar 26, 2020
    ironass and N1544725203334 like this.
  15. Caomhin
    KitKat Mar 26, 2020
    Ashishrazz
    facing some issues [e]1f622[/e]​
    Aren't we all. No sports, no beer, the missus nagging.
    What are your issues on the Software?
    drl431, ironass and kjjm like this.
  16. Ashishrazz
    Ashishrazz , Mar 26, 2020 :
    camera stopped frequently [e]1f622[/e]
  17. Caomhin
    KitKat Mar 26, 2020
  18. Ashishrazz
    Caomhin likes this.
  19. N1544725203334
    Caomhin likes this.
  20. sohan_ricky
    Donut Mar 26, 2020
    sohan_ricky , via OnePlus 6 , Mar 26, 2020 :
    after this update. almost using this oxygen os version 10.3.2 from last 2 weeks. facing unwanted restarts and over heating issues!
    @OnePlus #OnePlus kindly guide us if you're listening.
    already done a hard reset!
    MCunha likes this.
