181
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. bjrg
    Honeycomb Apr 3, 2020
    bjrg , Apr 3, 2020 :
    I don't have this problem now but had this in one of the previous updates where the sound used to leak from the main speaker despite being connected to Bluetooth earphones. Suggest you to reset the Bluetooth settings once as well as unpair/repair the Bluetooth earphones. Before doing this, check whether the media output to selected to Bluetooth.
    Caomhin likes this.
  2. Gotzegot
    Cupcake Apr 3, 2020
    Gotzegot , Apr 3, 2020 :
    Thats what I already did. I've backed up all my data and Im in the midst of a factory reset to ensure that my "dirty" update didn't cause the bug
  3. Gotzegot
    Cupcake Apr 3, 2020
    So I've just done the reset, and now it works, which is fabulous
    I just am stuck wondering what was causing it. Additionally, I need to get root back onto the device and see if that impacts it.
    Caomhin likes this.
  4. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 3, 2020
    Caomhin , via OnePlus 6T , Apr 3, 2020 :
    I do use it extensively, as currently in lockdown where I am from.
    I don't do gaming or streaming, I have an Android box for Streaming.
    If you check my previous posts for battery life they all come up similar.
    I have nearly all 3rd party apps on Optimized, I always kill my recents after use of the apps, I also use Fast Task Killer app to free up memory.
    I leave the phone plugged in overnight, every night. I don't have junk apps on the phone that I have no use for.
    I reboot the phone at about once per every 1 to 2 days.
    And I regularly get the battery life you see with, give or take, about 20% battery left at the end of the day
    Danny_boy and drl431 like this.
  5. EL1TxE
    Gingerbread Apr 3, 2020
    Caomhin likes this.
  6. A1550387522048
    A1550387522048 , via OnePlus 6 , Apr 3, 2020 :
    I actually charge my battery up to 70-75% every day while the battery life still shows 20%. And I recharge 2 times up to full 100% per month. Maybe this also is effecting on adaptation of the battery life. But I use all apps what I need. No gaming, no Instagram, no Facebook but Twitter and Linkedİn I have. I do more streaming in hires audio either by Bluetooth or cabled headphone. I believe the apps strongly effected on the energy management in the devices.
    Caomhin likes this.
  7. jsachin45
    Cupcake Apr 3, 2020
    jsachin45 , Apr 3, 2020 :
    this update sucks. My screen goes black with only indicators blinking. This happens every other 30 minutes. Only cure i found is press your power button for 13 seconds or so and then the phone restarts. Everything goes back to normal for next 30 mins and then it crashes again. All my meetings and calls are getting disturbed because of this.
  8. jsachin45
    Cupcake Apr 3, 2020
    The only reason i was happy being with One plus family was its Stability. I never faced this issue before. But in last couple of months i am thinking otherwise because of faulty patches you people push to our phone. I hope the coming updates are stable enough else i am thinking of switching to another brand.
  9. Caomhin
    Do a full Erase/Delete Data button, factory reset. This will restore you to a fresh installation of Android. So you will need to backup your phone.
    After Backing up the phone.
    Go to Settings, System, Reset Options, Erase All Data, click on the Delete All Data button,
  10. Stark0207
    Eclair Apr 3, 2020
    Caomhin and EL1TxE like this.
  11. F1585914941466
    Cupcake Apr 3, 2020
  12. F1585914941466
    Cupcake Apr 3, 2020
  13. rhyd1am
    KitKat Apr 3, 2020
    rhyd1am , via OnePlus 6T , Apr 3, 2020 :
    Not much point showing that, without also showing the full usage. If I were to charge my phone 3 or 4 times during the day, but unplugged it before nearing full charge, then I could also get that kind of screen on time.
    Just saying 🤷‍♂️
    Caomhin and drl431 like this.
  14. U1585914800785
    Cupcake Apr 3, 2020
    U1585914800785 , Apr 3, 2020 :
    Hi!
    I just subscribed Disney+ in Germany and cannot install the app. Message is saying, that 'this item is not compatible with the Oneplus6'. This is the first time I got such a message while installing an app from the play store.
    Am I the only one to experience this? Any hints?
    Kind regards
  15. EL1TxE
  16. Smeghead0301
    Cupcake Apr 3, 2020
  17. rhyd1am
    KitKat Apr 3, 2020
    U1585914800785
    Hi!
    Kind regards
    I'm in no way an expert on any of this, so I may be wrong here. I think from the little I've read, that it's too do with DRM Widevine level. The level that Disney plus is using is 3, whereas OnePlus 6 is only level 1.
    Edit: It downloads ok on my 6t. Is your bootloader unlocked or you have root by any chance?
    Caomhin likes this.
  18. Caomhin
