179
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. AanandRoy
    Froyo Apr 8, 2020
    Abhishek_Singh_2 likes this.
  2. Abhishek_Singh_2
    Gingerbread Apr 8, 2020
  3. walyoo
    Donut Apr 8, 2020
  4. Caomhin
    Lollipop Apr 8, 2020
    Caomhin , via OnePlus 6T , Apr 8, 2020 :
    Developers at Activision are still not updating to make the COD game Android 10 compatible huh...!!!
    Shame on them.
    walyoo and Artemus. like this.
  5. U1586357017293
    Cupcake Apr 8, 2020
    U1586357017293 , Apr 8, 2020 :
    when i Click on autorotation My Phone goes 180° my sensor Not working or its A Softere problem
    Caomhin likes this.
  6. Caomhin
    Check if you have installed a 3rd party app that is allowing this 180° feature.
    Artemus. and U1586357017293 like this.
  7. U1586357017293
    Cupcake Apr 8, 2020
    no i factory restore my phone 2 time but still facing this problem Camera also Capture invert Imagines
    Caomhin likes this.
  8. Caomhin
    If you have wiped your phone completely already without reinstating 3rd party apps and it is still happening, then I suggest you contact OnePlus support directly for more information on your issue. Scroll down the page for contact/chat details.
    Artemus. and drl431 like this.
  9. Caomhin
    Info as requested by message.
    Downgrade Android 10 to Android 9 check @ironass post link below
    https://forums.oneplus.com/threads/...eplus-6-and-6t.1174291/page-193#post-21315967
    [e]26a0[/e]️The above links DO work. If you cannot open them using the OnePlus Community app, copy the link to an external browser or log into community in your Google Chrome browser and click the link from there[e]26a0[/e]️
  10. 19ayaN
    Donut Apr 8, 2020
    19ayaN , via OnePlus 6 , Apr 8, 2020 :
    Hi,
    There no option for backup the device so that i can reset with proper backingup the data. I have not checked earlier but from yesterday I tried like any thing to backup through google drive or google ac. I have delete G-Ac and clear device cheche restarted several times. tried with different wifi network and mobile data of different operator( Airtel, BSNL, Vodafone). There is showing waiting for backup but nothing going forward or not going to the end the process.
    Please help whats the solution regarding this.
    Caomhin likes this.
  11. Caomhin
    19ayaN
    Hi,
    Please help whats the solution regarding this.​
    This appears to be a common problem with Google and it appears to be a bit random. It's not phone make or model specific
    The link here has some details and possible solutions that worked for some.
    https://www.androidpolice.com/2019/...phones-for-months-no-proper-fix-in-sight/?amp
    Further suggestions here.
    https://www.jihosoft.com/tips/fix-google-backup-not-working-android.html
    ironass likes this.
  12. edyaldea
    Froyo Apr 8, 2020
  13. Caomhin
  14. 19ayaN
    Donut Apr 8, 2020
    Thanks for the info. Also my problem solved automatically just some time before. my data have been backedup also check in the g drive at the backup section.
    Thanks again for you info.
    Caomhin likes this.
  15. Caomhin
    Glad to hear you got sorted. [e]1f44d[/e][e]1f601[/e]
  16. A1550387522048
    A1550387522048 , via OnePlus 6 , Apr 8, 2020 :
    I've experienced yet a new bug..after 25 days in stable and good going with 10.3.2 today evening the battery began to drain fast then before...I checked all apps and settings however I found there is nothing to effect this.
  17. Caomhin
    Have you installed any new apps or updated any apps within the timeframe the battery draining started?
    Sometimes it could be an app update, check Playstore for a list of recently updated apps
  18. ironman93
    Donut Apr 9, 2020
    ironman93 , via OnePlus 6 , Apr 9, 2020 :
    its not upto them op team is doing nothing about that. i have other a10 devices on which it is working like charm...
    blameoneplus not Activision
    A1550387522048 likes this.
  19. K_deep
    Gingerbread Apr 9, 2020
    K_deep , via OnePlus 6T , Apr 9, 2020 :
    A strange problem is arising in my 6T..whenever i am on call using the earpiece (screen gets off that time), initially it works well..but after few seconds during call other party is not able to hear my voice..while i can hear their voice..but if i pursue the call using loudspeaker(screen remains on during the call) then no such problem is arising and my voice is audible to other party during call..i am receiving half of signals on my phone..what should be the solution for this problem??
