179
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. Kytharsis
    Nougat Apr 9, 2020
    Kytharsis , Apr 9, 2020 :
    It is actually up to Activision. This happens on other A10 devices.
    Trevor.Hawkes, Caomhin and Auristic like this.
  2. U1586357017293
    Cupcake Apr 9, 2020
    U1586357017293 , Apr 9, 2020 :
    i have downloaded old version but when i want to Downgrade My Phone show that you are not allowed to downgrade from local updates
  3. Tee_Eee_Bee
    Honeycomb Apr 9, 2020
    Tee_Eee_Bee , Apr 9, 2020 :
    You can't install an OS version with an older build date than your current version.
    You'll need to downgrade to Android 9, then upgrade to whatever version you like, or wait for the next stable release, or
    if you want, you could install Open Beta 6 (newer build than 10.3.2, so a wipe is not needed)
    Remember to back everything up as a downgrade will wipe your device, instructions can be found here:
    https://forums.oneplus.com/threads/...eplus-6-and-6t.1174291/page-193#post-21315967
  4. Iheb87
    Cupcake Apr 9, 2020
    Iheb87 , Apr 9, 2020 :
    i don't think so
  5. edyaldea
    Froyo Apr 9, 2020
  6. Twiny
    Eclair Apr 9, 2020
    Twiny , Apr 9, 2020 :
    Can apps be added to this list? (Battery Optimization)
  7. Caomhin
    Lollipop Apr 9, 2020
    Kytharsis, kjjm, drl431 and 3 others like this.
  8. A1550387522048
    Gingerbread Apr 9, 2020
  9. Caomhin
    Caomhin , via OnePlus 6T , Apr 9, 2020 :
    No, only the apps that OnePlus allow Optimisation, all 3rd party apps are on the list, System apps are not on the list for a reason, as they are apps used to run the system.
    If you check on the App Info, Battery section of the apps not on the list, you will see that Optimisation is not anoption
    Twiny and drl431 like this.
  10. Caomhin
    Clear Chrome App info cache, see if that helps.
  11. A1550387522048
    ironass and Caomhin like this.
  12. A1550387522048
    A1550387522048 , via OnePlus 6 , Apr 9, 2020 :
    I did do everything ..Even wipe caches etc. but it is insisting. Anyway they can solve after feedbacks.
    Caomhin likes this.
  13. Caomhin
    It's happening on many phones, I even searched it for you. Click the link below, many sites, many phones, many suggestions. Have a browse through them see if any fix your issue. If not Activision are to blame.
    https://www.google.com/search?q=cod...nt=ms-unknown&sourceid=chrome-mobile&ie=UTF-8
    ironass and Trevor.Hawkes like this.
  14. Caomhin
    Ok, at least you pinned it down.
    A1550387522048 likes this.
  15. Nabeel_OnePlus6
    Cupcake Apr 9, 2020
    Nabeel_OnePlus6 , Apr 9, 2020 :
    Ever since i updated my OnePlus 6 to this release, my Dash Charging has been disabled. Fast Charging is not working.
    MTP is also not working at all, Whenever i connect my phone to the laptop, it charges only and shows no options to choose MTP at all.
    I can't even save my data to laptop to do a factory reset to see if it works for me.
    Kindly release a patch with the fix.
  16. Caomhin
    Clean the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden toothpick carefully.
  17. Nabeel_OnePlus6
    Cupcake Apr 9, 2020
    What does update have to do with dust ?
  18. Caomhin
    Android 10 seems to be a bit more sensitive to connections made, a number of people had the same issue you have, cleaning the ports fixed the issue in many cases, not all.
    So it's worth a try, as dust in the air can ingress into the ports, and lint in your pocket can sometimes ingress into the port on the phone. It's just life, open ports gather the detritus around us all the time.
  19. A1586427933750
    Cupcake Apr 9, 2020
    A1586427933750 , Apr 9, 2020 :
    please fix the screen recorder app . it doesn't record the hole screen ' in oxygenOS 9 was excellent'
  20. Caomhin
    Backup any recordings made, then Clear Screen recorder App info Cache and Storage cache
    If this still doesn't fix it contact OnePlus support directly for more information on your issue. Scroll down the page for contact/chat details.
    A1586427933750 likes this.
