181
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. Sharry7
    Ice Cream Sandwich Feb 27, 2020
    Sharry7 , Feb 27, 2020 :
    People still use viber?
  2. DaRk_ChAoS69
    Eclair Feb 27, 2020
  3. SanderBos
    Froyo Feb 27, 2020
    SanderBos , Feb 27, 2020 :
    You can fix it yourself by installing an app, if it is bothering you enough to use the caps lock, Nacho Notch:
    https://play.google.com/s...ils?id=com.xda.nachonotch
    I use it, and it works great (some apps will have invisible navigation buttons at the bottom, but they still work).
    Getting rid of the notification of this app can be tricky, especially the Android system one. But it can be done, if you keep trying... One thing to try is to Go to Settings|Apps and notifications|All x apps|... menu|Show system apps|Android-system (note: there is two of those!!)|Notifications and look the Nacho Notch notification, but it may not be there. You can then start the Nacho Notch app and switch back to the settings, then it shows up for me).
  4. RapchandoseBuoy
    RapchandoseBuoy , Feb 27, 2020 :
    thanks bud
    but i would prefer a stock option like it used to before
  5. Alessandro Miccono
    Donut Feb 27, 2020
    G1541777717518 likes this.
  6. Caomhin
    OnePlus 9 Series Expert Community Expert Feb 27, 2020
    Caomhin , via OnePlus 6T , Feb 27, 2020 :
    Beta 5 is older build 19/02/20
    10.3.2 is Newer build 22/02/20
  7. G_SayIDidIt™
    Gingerbread Feb 27, 2020
    G_SayIDidIt™ , via OnePlus Community App , Feb 27, 2020 :
    SanderBos
    I use it, and it works great (some apps will have invisible navigation buttons at the bottom, but they still work).​
    I also use Notch Notch but would prefer if I didn't need to. Two reasons, each time the phone restarts, it doesn't always enable automatically. And two, I hate the persistent notification.
    Edited to fix spelling errors
    N1543267098402, DJKekz and Hury like this.
  8. SanderBos
    Froyo Feb 27, 2020
    Ah.
    It always starts up automatically for me, no issues there.
    But the notifications were indeed a royal pain to get rid of, especially the Android System one, that is true. It can be done, I don't have a persistent notification for it, and I did that on two phones, but I can't give easy instructions because it was not easy. So keep trying!!
  9. Sidhaarth mutreja
  10. 6.T
  11. O1527806823139
    Cupcake Feb 27, 2020
    O1527806823139 , Feb 27, 2020 :
    i am missing the point but what do you mean ?
    its in display
    Caoimhín likes this.
  12. Artemus.
    Community Hero 2020 Feb 27, 2020
    Artemus. , Feb 27, 2020 :
    Pretty sure this is an A10 thing.
    Caoimhín and drl431 like this.
  13. RapchandoseBuoy
    before when you used to disable the notch, time and status icon will blend on top black part of camera notch
    now everything comes down and makes screen look smaller too
    like it have bezel on top
  14. Alessandro Miccono
    Donut Feb 27, 2020
    VasuJain1970 and Caoimhín like this.
  15. O1527806823139
    Cupcake Feb 28, 2020
    O1527806823139 , Feb 28, 2020 :
    ahh thank you mate .i was not sure
  16. G_SayIDidIt™
    Gingerbread Feb 28, 2020
  17. Gokul7373
    Honeycomb Feb 28, 2020
  18. Gokul7373
    #38
    richiebb and Venkat1991 like this.
  19. #39
    A-Josh87 and Girish.sajjan like this.
  20. Kunya
    Eclair Feb 28, 2020
    Kunya , Feb 28, 2020 :
    In which update *VoWifi registration for the Jio Sim* will be included!!!
    Becoz in beta 5, they where testing it with 2020.02 security patch only!!! and if the stable is pushed 2020.02, then VoWifi should also be included! isn't it?
    *haven't installed, just telling by seeing the change log provided in this Post*
    #40
    Chosen_One and Meet_GrimReaper like this.
