181
OxygenOS 10.3.2 for the OnePlus 6 and 6T
  1. alishan212
    Gingerbread Mar 4, 2020
    alishan212 , via OnePlus 6 , Mar 4, 2020 :
    I don't get more than 2.5-3 hours.
    I stopped caring about it long ago. it is what it is.
    Can't be helped.
    I've given up on expecting software updates to improve my situation.
    Got myself a power bank.
    Best thing I can recommend.
    lyes87 likes this.
  2. Harshk4889
    Donut Mar 4, 2020
  3. theonteg
    Froyo Mar 4, 2020
    theonteg , Mar 4, 2020 :
    According OnePlus support team in Android 10 software itself have designed status bar in this respective manner...
    So we will not wait changes in the notch issue...
  4. Gokul7373
    Honeycomb Mar 4, 2020
  5. Auristic
    Lollipop Mar 4, 2020
    Auristic , Mar 4, 2020 :
    "You are fake news!": please go spam elsewhere.
    drl431, Caoimhín and ironass like this.
  6. rhyd1am
    KitKat Mar 4, 2020
    Caoimhín likes this.
  7. efks
    Ice Cream Sandwich Mar 4, 2020
    efks , Mar 4, 2020 :
    Screenshot_20200304-183743.jpg like always did factory reset yesterday. today first full discharge
    AntInPhilly likes this.
  8. Gokul7373
    Gokul7373 , via OnePlus 6T , Mar 4, 2020 :
    Maybe you have understood wrong....See other devices from the left swipe the arrow should be in right direction but it is in a reverse direction......
  9. syedrhashmi
  10. pksivaprakash
    Eclair Mar 4, 2020
  11. Rohit Hedage
    Cupcake Mar 4, 2020
  12. vlc_marcos
    Donut Mar 4, 2020
    vlc_marcos , via OnePlus 6T , Mar 4, 2020 :
    hello all,
    quick question, after upgrading to the last stable version my Google photos stoped working, is there anyone having the same issue, and if yes how did you solve it?
    thank you
    SamsungRefugee likes this.
  13. rhyd1am
    KitKat Mar 4, 2020
    rhyd1am , via OnePlus 6T , Mar 4, 2020 :
    Have you tried clearing the cache and data for Google photos?
  14. aniketk0022
    Donut Mar 4, 2020
    aniketk0022 , Mar 4, 2020 :
    Same here just I did the update via oxygen updater, I am facing lag in few apps, also lag while moving back or using home gesture, please bring next update soon
  15. Caomhin
    OnePlus 9 Series Expert Community Expert Mar 4, 2020
    Caomhin , via OnePlus 6T , Mar 4, 2020 :
    Wipe cache partition
    Turn off your device.
    Press and hold the Volume down and Power button at the same time.
    When the OnePlus logo appears, release the Power button, but continue holding the Volume down button.
    At the Password screen, enter the Password or PIN number that you use to unlock your device. When done, tap Ok.
    Tap English.
    Tap Wipe data and cache.
    Tap Wipe cache.
    Tap Yes to continue.
    Tap Reboot to restart the phone.
    [e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️NEXT[e]2b07[/e]️[e]2b07[/e]️[e]2b07[/e]️
    Go to Settings > Apps & notifications > see all apps > select three dots > Reset app preferences.
    Then reboot.
    This will not delete your apps data but you will have to provide permissions again.
    Just in case there is an App hogging resources, causing Lag, Heat, Battery drain or freezing, clear your recent apps, also try setting 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    Also charge your phone to full and restart it after optimizing, and see if that helps.
    Check App battery stats at about 50% and see if there are particular apps using more battery than necessary.
    aniketk0022, ironass and rhyd1am like this.
  16. F1575774640174
    Cupcake Mar 4, 2020
    Meet_GrimReaper likes this.
  17. RapchandoseBuoy
    RapchandoseBuoy , Mar 4, 2020 :
    what happened to NEVER SETTLE?
  18. LegolasX
    Jelly Bean Mar 4, 2020
    rhyd1am and Caoimhín like this.
  19. F_Matty_Jasper_kUPO , via OnePlus 6T , Mar 4, 2020 :
    Amen to that! The single worst issue with this whole Android 10 rollout! Happens on my 6T and my wife's 7T! 🙄 Maybe it's an Android 10 OS level bug rather than a OnePlus issue, I don't know 🤷‍♂️
    Gokul7373 and Caoimhín like this.
  20. Caomhin
    It seems to be a fairly random issue, you say it happens on your phones and yet I don't experience that issue, nor any other issues mentioned here.
    I can understand the frustration, but I also have a 6T. So I dont understand how one 6T can have this, and yet another doesn't.,the hardware is the same, as is the software if you are on 10.3.2 on 6T.
    I am currently on WhatsApp 2.20.58,although it never happened on previous version.
    Am also on Gallery version 3.8.21 from apkmirror.
    Unless another app is causing a conflict which then causes the freeze. Would be interesting to get to the bottom of the issue, as I don't believe it's OP6T hardware/software causing it. It must be either a setting or another app.
    ironass and Trevor.Hawkes like this.
